u joints
Old May 6, 2012 | 08:45 PM
railroaderone's Avatar
u joints
I just put the new XRF ball joints in my truck and thought the outter U joint was good but now I have a cap seized. I replaced them about 40k ago with NAPA joints and was woundering if there is a better u joint avaiable. Thanks in advance
Old May 6, 2012 | 09:22 PM
Crobar's Avatar
Funny thing I just came in from the garage where I was replacing another NAPA Chinese made lifetime warranty u joint.
Lifetime or not they only last 20 or 30 thousand because the grease takes the path of least resistance and does not go to all 4 caps.
Went to Spicer Life series 5006813.
Old May 6, 2012 | 09:57 PM
hot_runner58's Avatar
I have replaced 3 sets, 2 o'reilys and one Car quest. so far all last about the same..... I am interested to know how those spicer's last. the best trick I found for changing the u-joints out, and maybe u guys know, none of the people around here seemed to know this, but after I get the drive line out, I put a thin cut wheel on the grinder and cut the legs off of the joint, then pound the caps inward. a lot easier.
Old May 16, 2012 | 02:00 AM
Alaskaskiff's Avatar
I seem to get about 5 years out of the precision 464 u joints in the front axle. Just did one tonight. I cut the u joint with the plasma cutter and drove the caps in with an air hammer.
Old May 16, 2012 | 05:14 PM
papaduck's Avatar
A thought that I had after replaceing the drive shaft U-joints. The grease that came in the joints if extreamly stiff. That grease needs to be removed to allow the grease gun grease to get to all 4 bearings.
Try greaseing a new cross with the bearing cups off and you can see what I mean.
I like to fill the cup with grease and when it is put on the cross the excess grease will exit the zerk opening.
Old May 17, 2012 | 07:38 PM
Crobar's Avatar
Cleaned that thick grease out of the NAPA u joints with the same thinking in mind. Still did not get grease to all 4 caps so went bad.
The good news is I have done it so many times now I can easily replace a wheel u joint in less than 2 hours. Refreshments included.
The bad news is I have done it so many times now...
Old May 17, 2012 | 07:47 PM
Dr.Dizzle's Avatar
I recommend the Spicer Life Series u-joints for those of you that value your time.
Old May 17, 2012 | 08:58 PM
RTillery's Avatar
Anyone know of a good online source for the Spicer Life u-joints?
Old May 17, 2012 | 09:02 PM
Dr.Dizzle's Avatar
Contact George at 8 Lug Truck Gear for the Spicer u-joints.
Old May 17, 2012 | 10:45 PM
torquefan's Avatar
x2. They are all I'll use too. (and I know I sound like a broken record about it on here too. ) My 96 came from the factory with all Spicer Life joints, and they are all still original, except for the front axle joints.
kprc51
Jun 14, 2007 06:27 AM
njmaier
15
Jul 26, 2006 07:43 AM
getblown5.9
May 2, 2006 10:01 PM
Seeder
Feb 15, 2006 08:15 PM
Dynocon
Mar 5, 2005 06:24 PM
