U-joint under warranty ?
Old Sep 1, 2008 | 09:08 PM
Fergy1960's Avatar
I am past the 3yr/36 and have a bad u-joint at the rear: wondering if the engine /drivetrain covers u-joints?
Also curious about wether any of the transmission is covered at this point?
What is your experience?
I would ask the dealer but I have lost all trust in them.
Old Sep 1, 2008 | 09:31 PM
donhov's Avatar
What year truck? Does it have the 7yr/70K warranty? More info needed to answer your question.
Old Sep 1, 2008 | 10:01 PM
Fergy1960's Avatar
The truck is an early 2004 305/555 48RE with 47,000 miles and has the 7/70 warranty
Old Sep 1, 2008 | 11:30 PM
metalbasher's Avatar
Its covered under powertrain warranty, had both of my front axle u-joints done.
Old Sep 1, 2008 | 11:56 PM
Fergy1960's Avatar
Thanks for the info metalbasher
Old Sep 2, 2008 | 06:40 PM
donhov's Avatar
Just remember the 7/70 has an $100 deductable. If youa re mechanically inclined you can change them for less than the $100 and get better thant he factory joints. Just a thought. And if you are having tranny progblems there is just 1 deductable so if all are combined than it would be to your advantage to have the dealer warranty it.
Old Sep 3, 2008 | 03:43 PM
Ram Daddy's Avatar
and just HOW do you know when the u-joints are bad?
Old Sep 3, 2008 | 09:56 PM
Equalizer 2's Avatar
One sign is a line of grease all over the underside of the truck in line with the u-joint. Another indication is a vibration on take off or deceleration. If your hearing is good you might hear the vibration also.
I have had the same one go out twice, first at about 32,000 miles and then at about 65,000 miles. I replaced it myself the second time with a greasable one from NAPA.
Old Sep 3, 2008 | 11:41 PM
BroncoAZ's Avatar
I've had numerous u-joints fail on my Bronco in the past. Mine have always started squeaking at low speed before failing. Another way to see if the u-joint is failing is to try to move the driveshaft. If there is any play in the joint it is definately bad.
72dart
Jun 19, 2012 10:42 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
ARAcummins
Jan 4, 2005 11:49 AM
