U-joint problems
Old Apr 22, 2005 | 09:09 PM
glowball's Avatar
U-joint problems
Had my u-joints go bad around 43,000 miles. Got stuck in Wenatchee for 6 hrs waiting for the local dealer to find some. My buddy just had to replace his at 25,000. The shop he went to said that he has done 5 dodges in the last month. He said something about dodge losing a contract with who ever used to have there u-joints in the dodge trucks. He showed my buddy why they are going bad.
So if you are feeling a major vibration at low speeds like less than 15 mph. Kinda like the truck is going to shake apart. It's probably your u-joints.
Kris
Old Apr 24, 2005 | 02:51 PM
Hummin Cummins's Avatar
I had the same problem at 52k on the clock. Rear most U-joint (at the rear the driveaxle) went bad.
Old Apr 25, 2005 | 08:20 AM
silverpullit's Avatar
just like Hummin Cummins, my u joint went bad at 53000. $125 dodge u joint. all four ball joints bad at 31000 replaced by dc at no cost to me. now at 53000 the replacement sets are on their way out. i'm now looking for a aftermarket set with a lifetime warranty. that must be why dodge placed the HEAVY DUTY on the REAR of the truck!!!!!!!!! all in all still love the cummins!
Old Apr 25, 2005 | 09:08 AM
glowball's Avatar
Spicer makes a replacement that should last a long time. Drivelines Northwest up here in Washington will changed em out for $12 a piece + the cost of the u-joint. Much better than the $261 I paid for two in Wenatchee.
Kris
Old Apr 25, 2005 | 07:27 PM
Muzzy's Avatar
Which u-joints are everyone referring to? The rear drive shaft (pinion end or transfer case end)? Anyone had problems with the front axle u-joints? I just had my drive shafts out to put my new clutch in and both front/ rear u-joints appear to be in good shape. I have 22k miles on my truck, so I will keep an eye on them.
-Muzzy
P.S. What is the part number for the spicer replacement and are they greasable?
Old Apr 26, 2005 | 08:42 PM
redneck1's Avatar
My U joint went at 60000. The one by the T case. Does anyone have any suggestions on aftermarket u joints? Hopefully greasable.
Old Apr 26, 2005 | 10:04 PM
StrokeThisCTD's Avatar
my step dads truck went in today for u joints at 98,000 miles. 1500 dollars worth of work apparently
Old Apr 27, 2005 | 01:38 PM
Gypsyman's Avatar
I lost the center joint last weekend at 62k. My 3500 LB with the 2 piece rear shaft got 3 new Spicer/Napa 351 greasable u-joints. I'm changing out all of the fronts to greasable today as soon as I cross the joints over to Napa numbers. The 351 joints have much larger needles inside the caps and seem to be a heavier design all around. Oh yeah, about $24.99 each from Napa.
Just a light touch to the sharp edges inside of the yokes with a round file and they dropped right in.
Richard
Old Apr 27, 2005 | 05:43 PM
Gypsyman's Avatar
Quick update. I was on my way to Napa for the front u-joints and happened to pass my local driveline shop so I stopped in to see what they would charge. Had all three of the fronts on my 3500 changed to greasable Spicers for $63.
Here are the Spicer numbers (for the 3500 front driveline anyway)
2ea. Spicer 5-213X (1330 series)
1ea. Spicer 5-3147X
Hope this helps.
Richard
Old Apr 27, 2005 | 09:35 PM
Forstner's Avatar
Had mine changed on warrantee in N. Carolina at 30,000 miles. The one near the differential was dry and rusty. Vibrated bad at 65 mph. They put in a factory replacement , non greasable,the part said Spicer on it. The drivetrain/ differential expert peened the snot out of one part of my yoke. I was going to change it myself,but the friend that I was staying with said let warrantee cover it. Plus the numbers would not cross reference at the after market stores. Anyway I did climb under and measure things up. The bearing cup is a 1 3/8" and the part # is 351 at NAPA (Precision) and greasable. 2003 HO w/ 11.5 ring gear. SO are different. It is amazing the size of that U-joint. My '68 1-ton takes a 1" bearing cap. By the way ,they wanted to rebuild the rear axle because of a little howl at certain speed, not after what I saw of my yoke the next day! Darn hillbillies! I'm one also, guess I made it a little farther than that one.
72dart
Jun 19, 2012 10:42 PM
DJ Turbo.
Oct 13, 2011 09:11 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
