Turning engine over without starting it
Old Nov 10, 2016 | 08:29 PM
wrecks2020's Avatar
something broke in my truck today (06 5.9 auto) while driving. Had it towed and now trying to crank it over to diagnose awful noise and not have it start... which fuse do I pull?
Old Nov 11, 2016 | 07:11 PM
StealthDiesel's Avatar
The easiest way to crank the engine over without starting is to jump the starter motor with the ignition key in the off position.
On my 2004.5 truck, you can follow the primary solenoid wire (yellow in my case) to a connector just in front of the pwr mgnt module (fuse box) in front of the driver's side battery.
I just use a remote starter switch between this wire and +12V at the battery to crank the engine.
Old Nov 12, 2016 | 01:39 AM
CRF450R RIDER's Avatar
you could also crank it over by hand using the nut on the back of the injection pump. it will go slower so maybe you hear the noise better or maybe feel something
JARHEAD
19
Apr 1, 2008 11:34 AM
turbomike
Nov 9, 2007 09:49 PM
j
Apr 2, 2007 03:37 PM
tlmac
May 14, 2005 11:16 PM
bigfoot
Aug 14, 2004 02:22 PM
