Turbo barking
Turbo barking
Pulling 23,000# load that i pull weekly, today pulling up hill i started to hear what i guess you would call turbo barking or shutter at half throttle so i can keep my egts under control. Dont have a clue whats going on seemed to get worse each hill that i would climb until i unhooked cant get it to do it with out the load.
Barking is caused by rapid deceleration of the turbo's fan blades (look up cavitation if needed) it should only occur when suddenly letting off the gas while the turbo is spooled up.
As you let off the gas quickly the engine no longer needs the amount of air being forced, it is sent back through the system (path of least resistance) until it hits the turbo where it tries to reverse the direction of the blades.
I hope that is clear enough.
have you removed your silencer ring? you may be one of the rare cases, where removing the silencer ring will actually do more than make more noise. It wouldn't be the first time I've heard of a fueled HY truck benefit from silencer ring removal
is that a bad thing? or just something that happens?
yeah the silencer ring was removed but that was about 15000 miles ago and alreeady have the afe stage II but iam gonna clean it today thanks for the advice cause i realy have no idea.
gman07
Apr 15, 2006 08:32 PM
Stamey
24
Jul 1, 2003 09:32 PM
Maddog
Jan 2, 2003 09:57 PM
