Truck Will Not Start
Hey Everyone,
Yesterday I was hooking up my utility trailer and had truck running.
When I got into the truck to align it up, it stalled. It was like I had released
the clutch too quickly and choked it down. Now all it does is turn over and will not start up. Has anyone ever had this problem or any ideas what it might be?
Thanks
Thanks
Bad fca, bad rail pressure relief valve, leaking injector(s), bad cp3, low fuel pressure.
1 or more could be the cauz u have to start narrowing down. id start with checking your fuel pressure.
first check 4 any codes, key on off 3 times, then check your fuel pressure with a guage, if your under 100k u should still be under warranty. remove the module and c if it starts. Then tose the k&n in the garbage and get something better on, or the stock air box.
TXJClark
Dec 6, 2014 05:50 AM
Hunky Dory
May 13, 2013 08:09 PM
FirstGen1991
Dec 22, 2012 04:24 PM
CoolumConst
Oct 11, 2008 10:00 PM
