Truck stuck - Ball joints won't come out
03 4x4 2500. I had three ball joints basically falling apart. Have the hubs out, knuckles off, driveshafts out of the way, the whole bit.. but now I cant for the life of me get the ball joints out. Already broken an OTC ball joint press, and some autozone ones. Also broke my wrench on the OTC ball joint press.
Ideas?
I don't care about breaking/burning the existing ball joints cause I have DynaTrac ones to put in.. but ***....
No truck unless someone has a brighter idea than me...
heat? If so, where? Only have a propane handheld. Can I cut them out with my 4 1/2 cut-off wheel grinder and dremel somehow?
No compressed air, this is my driveway...
Thanks
Justin
Ideas?
Thanks
Justin
Some heat and PB blaster along with some patients works wonders. For the lowers I use a air hammer while I'm putting about 100lbs of weight on it will drive them out easier than with a press. Be sure you have all c clips out to start with. To prevent this happening again, clean everything up real well with some steel wool or scotch brite pad and a decent coating of antiseze before you throw it back together will make future jobs a breeze.
LOL yea I got that wrong on the first one
Then it started going smoother... got em all now. Dynatracs are in.
Anyone have a pic of what fitting I'm supposed to use for that bottom "zerk" like grease fitting that's more flat than the normal ones with a nipple on em?
There is also a slide on sideways attachment for the lower BJ. I have been unsuccessful at getting the needle type on all of the joints I have replaced recently. Maybe the u-joint is larger than previous.
firebill1720
20
Mar 5, 2010 09:23 AM
redsealdodge
31
Dec 7, 2007 05:22 PM
Seeder
Feb 15, 2006 08:15 PM
