Transmission Temp Light
Old Dec 11, 2003 | 07:21 AM
Geets's Avatar
I was driving in to work today, 75mph, pretty flat terrain, no trailer in tow and I noticed for a quick second what appeared to be my Transmission Temp light flash. I could have swore this happened last week as well but I thought I was seeing things so I ignored it.
Has anyone else had this happen? I have the dreaded 47RE that everyone is talking about.
Old Dec 11, 2003 | 07:30 AM
RamDan03's Avatar
Re:Transmission Temp Light
There is a TSB that covers this issue:
http://dodgeram.info/tsb/2003/08-004-03.htm
Many users experience this problem, which can be corrected by the dealer if you choose to do so. My check gauges light flashes quickly sometimes on a cold day, but it's not worth the hassle of taking it to the dealer.
Hopefully this is all your problem is.
Old Dec 11, 2003 | 07:37 AM
Geets's Avatar
I just read the TSB but #3 says on a manual transmission equipped vehicle. Does this hold true for my automatic as well?
Models: 2002-2003 (DR) Ram Pickup
Symptom/Condition:
Three conditions have been identified which may be caused by communication errors between the Electro Mechanical Instrument Cluster (MIC) and other electronic modules on the vehicle.
1. An intermittent false "Check Gauges" on diesel engine equipped vehicles.
2. An intermittent false chime and "Low Wash" indicator. A valid "Low Wash" indication will occur for at least a 30 second Interval. With this false condition, the chime will occur followed by the "Low Wash" indicator which will last for a half second or less.
3. A "Trans Temp" Indicator on a manual transmissions equipped vehicle
Old Dec 11, 2003 | 07:41 AM
RamDan03's Avatar
I'm pretty sure some of the automatic folks have experienced it too. Maybe someone with an auto will chime in.
Old Dec 11, 2003 | 09:39 AM
bigtobe's Avatar
I have an auto and have experienced it. But it was the "check gauges" light that flashed for a quick second.
Old Dec 11, 2003 | 02:34 PM
Mike67RS's Avatar
I have had it happen twice.
Old Dec 11, 2003 | 06:11 PM
mitchkim's Avatar
the wife drove truck yesterday and came home and said some light was flashing very brief in the left had corner of cluster
thought maybe she was seeing things but this must have been what she was seeing
has not happened to me yet
Old Dec 11, 2003 | 06:34 PM
LinearX's Avatar
[quote author=Geets link=board=20;threadid=23578;start=0#msg221929 date=1071149850]
Symptom/Condition:
[/quote]
For what it's worth my Brake/ABS lights used to come on for no reason while driving down the road. My Check Gauges light came on a few times as well. After I had the TSB performed on my truck, the Brake/ABS, and Check Gauges lights haven't come back on since (in a false manner, that is). There is a good possbility that this TSB will cure your Transmission Temp light coming on erroneously as well.
Old Dec 13, 2003 | 12:54 AM
SuperGewl's Avatar
Yes it is the COMPUTER
Take it back and have them flash it ;D ;D. I had the same problem, it's all better now. I haven't seen it in 9 months.
Old Dec 19, 2003 | 11:24 AM
dawghlr's Avatar
I think it is the computer and they can reflash to fix it. On my truck it was the low fuel light on when I had a full tank and then it would evently go off but it took 10 min for the gage to come up to full they refashed in it works now.
Beefdoc
Jul 18, 2011 12:49 PM
hconstantino
May 3, 2010 12:15 PM
elucho02
Aug 15, 2008 10:31 PM
ngkefalides
0
Aug 12, 2008 08:33 PM
bigboy
Dec 21, 2007 08:24 AM
