Transmission Leak?
Old Oct 16, 2010 | 06:56 PM
ddszero's Avatar
Transmission Leak?
I was under my truck today looking for any problems and I noticed my transmission was covered in a light coating of oil. It looked as if the oil was coming from the top of the transmission and working its way down from the top. There are no puddles or even drops on the ground under the truck . The oil on the outside of the case is clean oil. I changed my transmission oil at 115,000. Is there any ides of where the oil is coming from?
Thank You.
__________________________________________________ _______________
2005 2500 Crew Cab short bed 4x4 with a NV5600 3.73 With Limited Slip
125,000 Miles, K&N Drop in filter
12K Mile Marker on TRANS4MER MOUNT
BFG KO AT 275/70 R17
Old Oct 16, 2010 | 07:17 PM
jokers's Avatar
Any chance that you slightly overfilled your tranny and the excess is now coming out a vent?
Old Oct 16, 2010 | 07:21 PM
Bill M.'s Avatar
My 07 with 75000 miles had a leak in a sensor or connection in the transmission when I went for the last oil change. about 80 bucks to cure it.
Old Oct 17, 2010 | 12:26 PM
calltrex's Avatar
or u could have a crack in the housing like mine
Old Oct 17, 2010 | 02:53 PM
ddszero's Avatar
Where a are the vents or vent located? On the top near the shifter?
Thank You
Old Oct 21, 2010 | 12:14 PM
cruizer32's Avatar
Trani Leaks
Well thats the story for my 03 2500 for the last month or so. Ive taken my truck in 4 times now to have the trani leak fixed. finally narrowed the leak down to the over drive housing has micro cracks in it. we welded up a few of them, and more appeared the next week. 330 bucks for a new OD housing is being installed right now. my guess is when the OD heats up, the cracks expand and thats why it only leaked on the drive way every now and then.
Old Oct 21, 2010 | 12:21 PM
Lost Lake's Avatar
Passenger side ???? That is common if it is.... Search for problem if it is passenger side top.
zig100
Mar 18, 2010 03:39 PM
george7941
Nov 28, 2009 09:28 PM
superdiesel9
Oct 25, 2009 07:56 PM
donhov
26
Jan 6, 2006 07:29 PM
Lightman
16
Jan 21, 2004 10:46 PM
