Transmission Help!!!!!
Old Sep 29, 2016 | 01:19 PM
midnight01's Avatar
So I am hoping that someone has experienced this with their truck as well, my 06 2500 HD CTD w/48RE, is having a delayed shift in 1st and 2nd gear. The truck is throwing a P0868 code and P1757 code one is low transmission fluid pressure and the other is 3 psi is present when 0 psi is demanded. I am at a loss i have replaced the transducer with the BD upgraded one, done the GM conversion Solinoid, and a new wiring harness. Someone please help. The transmission is a stage 6 ATS unit.
Old Sep 29, 2016 | 03:36 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
What does ATS say about it?
Old Sep 29, 2016 | 06:33 PM
midnight01's Avatar
They said its electrical but i don't know how its possible when i have replaced everything electrical.
Old Sep 30, 2016 | 08:04 AM
patdaly's Avatar
You say wiring harness, but the one in the trans or the external one?
I'm not familiar with the 3rd gens, but the second gens have a connector underneath the area by the drivers toe kick that can be an issue.
Time to start tracing wires/connector up to the PCM.
Old Sep 30, 2016 | 04:56 PM
midnight01's Avatar
I replaced the internal one. Could it be a bad or corrupt stock file in the ECM?
Old Oct 23, 2016 | 12:54 AM
Z-MAN's Avatar
I have the same issue. Can you please let me know what you found out?
Dauntless
15
Aug 30, 2016 08:37 PM
big_gatti
Jul 26, 2004 07:00 PM
Max Meade
Feb 11, 2004 10:01 PM
quantrill88
Mar 19, 2003 05:04 PM
straightpipe
Mar 7, 2003 04:09 PM
