transmission cooler
transmission cooler
I have an 06 Dodge Ram 2500 diesel mega cab, and pull a 5th wheel trailer, on the flat lands of Florida, 2 weekends each month......would you recommend a transmission cooler? My vehicle does not have one.
Thanks
Thanks
If it's an auto, your truck has 2 coolers. One at the back of the engine driver's side which is a fluid cooler and one up front that is an air cooler. Follow the lines from your tranny.
Pete
Pete
To really gauge if yopu need another/more cooling, get some gauges installed.
Also, if you are sitting, parked, in traffic, put the truck into neutral. If you are over ~15-20mph, even unlocked, the factory coolers work fine.
I've had thoughts about adding another cooler...even on 115F days, I have not seen over 180-190F. Once I get over 30mph (tow-haul mode or jake on) the TC will lock up and the trans temp will fall to <170. The 30mph lockup is if i'm easy on the throttle. If I hammer it, the tc won't lockup until 40-45 in 3rd.
Remember, it's not that the temps are spiking to 180-190, it's time at that temperature. If you are >230 for >30-60 minutes, get the fluid changed at your earliest convenience. If you run <200 all day, change it at the factory interval (30k). Rule of thumb with trans fluid: 170f is supposed to last 100k miles; 190F = 50k, and so on. Every 20F rise over 170F is a half-life. If you follow this out, at 130f the trans fluid should last 12.5k.
This does not take into account how many miles you already have on your fluid.
HTH
Tony
HTH
Tony
Tank_66
Jan 11, 2012 10:12 AM
lezmark7
Mar 29, 2003 09:47 AM
