trans service
Old Oct 19, 2008 | 12:21 PM
tt433's Avatar
trans service
I have a 04.5 with a 48re trans i want to service the trans. A guy told me i can drain the converter by taking out a drain plug. Has anyone heard of doing this and how much fluid?
Old Oct 19, 2008 | 01:48 PM
JRD's Avatar
JRD
As far as I know these trucks do not have a drain plug on the converter. As far as how much fluid...I can't help you there.
Old Oct 19, 2008 | 05:09 PM
mrblond's Avatar
my 06 manual say 4qts service fill and 29pts to 33pts overhaul.
Will you be using Amsoil full synthetic? I found it for 7.50 per qt bottle? Im buying 24qts.
Old Oct 19, 2008 | 05:43 PM
dozer12216's Avatar
No drain plug on converter and has not been one for over thirty years. Talk about behind the times.
Normal drain and refill is generally 5 - 7 qts. If you loosen bolts on valve body, some more will drain out. Just use ATF+4 from Wally World and be done with it.
Old Oct 19, 2008 | 05:50 PM
tt433's Avatar
thanks for the help
steelblitzkrieg
Oct 14, 2011 09:19 PM
dieselbeef
Jun 12, 2006 08:12 AM
Lightman
35
Dec 2, 2004 08:34 PM
bws
Jun 20, 2004 10:56 PM
Tackett
Apr 7, 2004 10:41 AM
