trans mount how much play
Old Oct 6, 2007 | 08:23 AM
adventuris's Avatar
i was under the truck checking ujoint when i push up on front end of rear drivshaft i can move the trans/ transfer case up and down pretty easy , how much much movment should there be .
Old Oct 6, 2007 | 08:37 AM
John Faughn's Avatar
Check the bolts for tight , are they wet with oil ? they can get soft if they are socked for long .
The drive train is mounted with rubber mounts so there would be a little movement , but not much .
You could remove bolts one at a time , & put back in with blue lock tight , after cleaning bolt & hole with brake cleaner spray .
Old Oct 6, 2007 | 09:06 AM
lowboy18011's Avatar
mine does same thing. Bolts are all tight and truck only has 20,000 miles on it. Just the way it is designed..
Old Oct 6, 2007 | 12:00 PM
wreedCTD's Avatar
what year is your truck lowboy?
Old Oct 6, 2007 | 12:28 PM
adventuris's Avatar
bolts are tight , no oil around area just a good 3/8 of movement up and down
Old Oct 6, 2007 | 01:40 PM
wreedCTD's Avatar
mine didnt move, maybe i didnt push hard enough?
Old Oct 7, 2007 | 09:11 AM
truck is 04.5
Old Oct 7, 2007 | 11:03 AM
Try to see where a gap is when you lift , could be that the rubber mount riped .
Old Oct 7, 2007 | 11:44 AM
adventuris's Avatar
mount does not look ripped when you push it up you can watch it strech that much , does not look ripped not seperated from the metal plates , just seems to much to me
Old Oct 7, 2007 | 12:09 PM
Do you get any banging when you run over rough road ?
If no banging then you should be ok .
klx650a2
Sep 19, 2008 09:28 PM
badme
May 17, 2007 08:46 PM
92DIESEL
May 27, 2005 12:20 AM
hellotbone
Aug 5, 2003 11:18 AM
