Trans Fluid Smell? ? ?
Old Mar 25, 2010 | 06:37 AM
skindaddy's Avatar
[B]i had changed my trans fluid and filter a couple weeks ago about 17qts, i did the pump out a gal & fill and repeat method.
Anyway now when the truck is up to temp. you can smell the trans fluid (Royal Purple), when idling. i was waiting to see if it would go away but its still there. its pretty strong sometimes!!!
Whats up with that?
Old Mar 25, 2010 | 07:15 AM
mq105's Avatar
Any leaks?
Old Mar 25, 2010 | 11:51 AM
skindaddy's Avatar
none that i have found , nothing on the ground either. will have to climb under and check again but not that i've found
Old Mar 25, 2010 | 12:22 PM
Shorts's Avatar
Wonder if this could it be similar to the "Rosmella" phenomenon?
Old Mar 25, 2010 | 11:29 PM
ranger1207's Avatar
I just changed my trans filter and trans fluid with Royal Purple. i am having the same smell, its been freaking me out do to the fact that this was the first time i did this type of service. can you explain "17qts, i did the pump out a gal & fill and repeat method"
Old Mar 26, 2010 | 07:03 AM
skindaddy's Avatar
first pumped out a gal and 1/2 then dropped pan, did the work and filled and drained, repeated to about 16qts or 17 couldnt remember exactly. i think it holds 17 altogether. i'm sure i pumped out some new also which i dont think about being $12 qt
DieselBD
Mar 3, 2026 06:01 AM
sharkbaitracing
Nov 9, 2010 08:20 AM
matrok
Aug 31, 2009 09:33 AM
icrider
Sep 27, 2006 03:10 PM
twhite
Jun 1, 2005 08:46 PM
