tranny troubles
Old Oct 17, 2008 | 03:07 PM
ram4tow's Avatar
tranny troubles
hey i think i may have screwed up lol. i tried adjusting the bands on my truck just the one on the outside of the case the adjuster screw w/loc nut .. anyways the adjuster seems to go all the way into the case and does not really seem to bottom out or anything which is what i think i need to get the proper torque values.. now the truck wont shift into 2 unless i let off the gas pedal completely. im not sure whats going on or what i did wrong but i was hoping someone herecould help me out ... thanks for any help guys
Old Oct 17, 2008 | 03:22 PM
coparam4x4's Avatar
How many miles on the truck and has it ever been adjusted before? Did you adjust the other band, that you need to drop the pan to get to? Also were you using an inch/lb torque wrench or ft/lb?
Old Oct 17, 2008 | 04:59 PM
uber_dzl's Avatar
make sure you used inch-lbs torque wrench or you will over tighten. If you're not feeling resistance and the adjuster screw is going all the way in, my guess is that the band is completely worn out or broken. It's only a guess but go in and loosen it then double check the torq.
Old Oct 17, 2008 | 05:22 PM
ram4tow's Avatar
the truck shifted fine before.. i had shuttle shift and i thought it might just need adjustment so i just did the one that was giving me problems which was the outside adjuster,, i did not drop the pan. i can put the adjuster bolt all the way into the case.. im not sure but if it was broken wouldnt the truck not shift at all past that gear?
Old Oct 17, 2008 | 05:24 PM
ram4tow's Avatar
i have 100 k on my truck and trans has been replace about 30 k ago by dodge under warranty. i guess i shouldnt have tried to fix something that wasnt broken lol.. any ideas on how to fix this ?
Old Oct 17, 2008 | 05:25 PM
ram4tow's Avatar
what is the torque values? i have them written down but i cant remember where i wrote them
Old Oct 17, 2008 | 05:52 PM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
I did it too.
LoL guess what you did???!!!! The same dam thing I did, 73000 miles ago.
The connecting link between the band and the apply servo piston has fallen out. Mine was in the pan when I changed fluid the next time. No big deal really. You just shift from 1st to 3rd and on up.
I actually have been procrastinating heavily about fixing the problem... for the last year and a half!
Drop part of the valve body bolts (9 or 10 total) holding the VB to the case, don't drop it completley out! Just loossend them up and let it drop down an inch or so. also, no gasket there or check ***** to roll out, and reach up in there with a magnet or needle nose pliers and put it back on.
I actually improved my mpg when that happened, but towing a trailer or going down a steep grade is a pain in the buttt.
Hope that helps.
db
Old Oct 18, 2008 | 05:30 PM
ram4tow's Avatar
so how did that manage to fall out ? what does the piece look like that might have fallen out? maybe i can install a shift kit while im doing this to get me throught the winter until i get my trans built . time to install it.. i really hope this is the problem i really has had me worried the past couple of days.. thanks for your guy's quick replys btw..
dan
Old Oct 18, 2008 | 09:10 PM
norwood dodge's Avatar
Did you back the adjusting bolt out ? If you remove the pan, the band strut will be in there. If not, tighten it to 72 inch pounds and back it off 2 1/2 turns. That should get you going.
Old Oct 19, 2008 | 05:57 PM
dozer12216's Avatar
Drop the pan and find out what is going on. Sounds like band now worn out.
Old Oct 20, 2008 | 09:50 AM
cdennyb's Avatar
The little piece is a cast steel spade shaped plate that has a counterbore in the one end to engage the cone shaped adjusting bolt (outside) and the other end is flattened to engage the band.
Doubtful anything is wasted... it just fell out. Like I said.. mine's been out for the past year and no problems or anything "worn out".
Sure, drop in a shift kit while you have it off, if you take it completley out. The linkage is a little pest occasionally but take you time, spend the better part of a Saturday doinbg it and you'll be fine.
Old Oct 20, 2008 | 10:04 AM
cdennyb's Avatar
here's what it looks like
this is page 2181 from the manual. Item no#3 is the one I'm referring to.
It should make you feel better about dropping the VB. This is what you're supposed to see when it comes down.
The other end very seldom comes off because the rotation is in a direction that keeps it wedged in there.
Hope this helps.
db
File Type: pdf
Old Oct 24, 2008 | 08:24 PM
ram4tow's Avatar
thanksalot guys im out of town right now im goin to put her on the lift and check everything out.. is that shift kit really going to help? i plan on buying a built tranny probably next summer.. but maybe it would be wise to do to get me throught the winter.. also is it a hard task to put in the shift kit.. i have a lift and most tools at my house but just dont want to get in over my head. thanks for all your help guys i appreciate it
Old Oct 24, 2008 | 08:27 PM
ram4tow's Avatar
any special tips to make this job go smoothly? or make it easier for myself thanks
Old Oct 24, 2008 | 08:42 PM
DreamSRT6's Avatar
Hope that helps.
db
I TOTALLY agree. i've played with those trannys enough to see that happen before. had a customer come in with a durango and we did the same procedure and it was gtg.
as far as the shift kit is concerned. when i did my first one, i had never worked on a tranny. i just followed the instructions and put it back together and it worked great! definitely made it shift better. much more direct. my next tranny i put a 5.0 ratio lever in and HOLY crap. nothing like chirping the tires with a hardly any effort.
anyways, GL
