tranny troubles
Old Nov 14, 2008 | 11:00 PM
ram4tow's Avatar
well boys.. i finally tore into the transmisson and sure as heck the flat bar + spade style adjustment parts were laying in my trans pan attached to the magnet lol. i had to drop the valve body to get them both back in place, all went smooth until i went to put the shift linkage back on the trans.. i noticed it has a notch in it so that the linkage can only go on one way.. but **** i cant seem to get it lined up for the life of me. Kinda a tight area to boot lol any tips on gettin it on there? i have the bolt backed all the way out but it still seems to be too tight ..
btw it went smoother than i thought it would.. thanks guys for your input..
Old Nov 17, 2008 | 10:22 AM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
check and double check the alighnment of the linkage rod, sounds like it's not engaged properly on one end or the other. Use needle nose vise grips... easier to hold and move without your fatt fingers getting in the way. Without seeing it upclose, I can't really give much advice... Sorry
Old Nov 23, 2008 | 08:39 AM
pete42's Avatar
THIS IS A NEW NEVER OPENED TRANSGO SHIFT KIT FOR THESE AUTOMATIC TRANSMISSIONS:
CHRYSLER DODGE JEEP
A518 A618 (48RE) 2003 THRU 2006 DIESEL & V10
THIS KIT IS FOR THE TORQUEFLITE/LOADFLITE OVERDRIVE TRANSMISSIONS.
THIS KIT WILL PROVIDE THESE UPGRADES WHEN PROPERLY INSTALLED:
Corrects/Prevents/Reduces:
Lube shortage
Soft shifts
Reduces drainback
Increases Torque Capacity
Adjust Lockup & Shift Firmness
Reduces converter slip.
Has Hi-Temp Low Shrink Rings
Perfect for Dodge Diesel and Gas Trucks.
Heavy-Duty Diesel.
You’ll hardly believe how powerful the shifts
can be without being bangy.
48RE Application Referance;
8th vin digit = C 48RE Transmission
8th vin digit = 6 47RE Transmission
This kit includes the TRANSGO Heavy duty Updated Valve-Body Separator Plate
THIS KIT CAN BE INSTALLED WITH THE TRANSMISSION IN OR OUT OF THE VEHICLE.
TRANSGO SK48RE
06blueRam
Oct 17, 2007 06:52 PM
54larry
Jun 3, 2007 01:04 PM
sledneck1
Apr 21, 2007 09:54 PM
apache
Jan 27, 2007 09:39 AM
roc155
20
Apr 7, 2006 10:16 PM
