tranny temp?
Old Mar 10, 2011 | 12:27 AM
WilderMike's Avatar
Thumbs up
Thor-
Right on! Thanks for the info. Got one on the way! Accurate gauges are GOOD gauges. Anyone seen an A-miller pod that'll hold four gauges? Thanks again
Old Mar 10, 2011 | 09:25 AM
alboy's Avatar
My 06 reads off the ECU 168/175 on the highway,new fluid will drop it 5/6 degrees.
Old Mar 10, 2011 | 11:06 AM
CoastalDav's Avatar
Originally Posted by WilderMike
Interesting....how are you guys tapping the hot (from trans) cooler line? I'm starting to think my Mag-tech pan sending unit position might not be as accurate as I thought! My trans is stock and normal driving I see 100 - 110 deg. A shade more with the 5er. Gauge starts at 100.... Thanks
I read my tranny temp via the Attitude Monitor (Edge Juice) It reads temp from the trucks computer. I understand the sensor is in the tranny valve body.
Best place to pull it from is at the entrance to the Air/Fluid cooler up front. Thats the hottest place. One in the pan will give you the other end of it.
The fluid leaves the tranny through a preheater on the side of the block that is cooled or warmed by the engine cooling fluid. From there it goes to the
cooler up front which has a in line thermostat that opens at a preset temp.
It circulates thru the cooler and back to the pan. I don't know if there is a bye pass at the Fluid to Fluid heater/cooler on the side of the block that sends it back to the tranny in a effort heat the fluid up quickly untill the thermostat opens up front.
Dave
wise_cummins
Dec 24, 2008 08:11 AM
Racing_Joe66
Jun 12, 2007 05:06 AM
jaconst
Jun 25, 2006 10:23 AM
turbox2
Feb 6, 2006 07:44 PM
firesine
Nov 24, 2005 10:58 AM
