Tranny shift points??
Old Feb 19, 2007 | 07:26 PM
kev94mx's Avatar
Thats my problem exactly. Seems like it is set up for interstate all the time running at high speeds.
Old Feb 19, 2007 | 08:33 PM
no_6_oh_no's Avatar
Originally Posted by kev94mx
I tried to get the dealer to change them the other day and they said the couldnt because Chyrsler want let them. Only there programs can be put in. Does anyone now if any place can go into the computer and do it? The way this thing searches for gears is so stupid. On my way to work you mite change gears in a 6 speed about 7 times this auto changes about 50. My fuel miliage is very bad to. In alot of ways I wish I had my 6 speed back.
The reason the dealer wouldn't do it is the shift points can't be changed in the ECU. The ECU only controls the TV pressure, no shift point or any other control.
The problem with the gear hunt is in the VB. The only one I have heard of so far that has consistently solved the problem is Dave Goerend. Give him a call and see what he has going.
If you want to change the way the trans shifts and holds gears then you have to modify more than the VB.
Old Feb 19, 2007 | 08:55 PM
dieselfan's Avatar
Originally Posted by own1bigtruck
Well maybe i got the oddball tranny! Mine doesnt want to go into overdrive until its over 50! I wish it would drop in around 40-45. I would understand it not dropping in until 50 if i was pulling in tow mode, but empty it seems to run way high before downshifting
If it did it would be lugging (less mpg)!JMO. speed up then slow down, if it bothers you.
Old Feb 19, 2007 | 10:22 PM
kev94mx's Avatar
Thanks I will check into it
Old Feb 20, 2007 | 01:24 PM
DBLR's Avatar
If you went in and just asked them to change shift points and not what your problem was then I can see them telling you what they did. IIRC I read some place that someone else had this problem and I thought he said there was a TSB about it. Anyway he had either his PCM or EMC reflashed and it took care of the problem with his trans hunting for gears all of the time so it might be worth the time to check through the TBS's.
Old Feb 20, 2007 | 06:03 PM
kev94mx's Avatar
That day they was suppose to check the computer . I dont think they flashed it to see if there was a problem.
Old Feb 20, 2007 | 06:28 PM
Spooler's Avatar
I have no problem at all with my tranny hunting for a gear. NONE!!!! It locks up at 45 MPH unless I have been or am pulling my horse trailer and it will lock up at 50mph on que. One thing has been done on the tranny since new. The previous owner complained of it hunting so they replaced the Governor. Can't remember if it was the pressure switch or the governor itself. Problem solved..... No more issues with that complaint. You just need to find you a good transmission guy that works at a dealership. Guess I am lucky the tech really knows his automatic transmissions. Said I would have no problems at all as long as I keep the fluid flushed every 30,000 miles and filter changed every 60,000 miles. He said in my area there are several 48re's with over 150,000 miles on them. Matter of fact that is mainly what they sell around here. Automatics Can't hardly find a manual that is why I have an automatic. I don't care for the TC but the thing is it will live for a long time just stock. I looked into a VB and TC. I am still on the fence on that one. Everytime you modify something it will stress another part of the transmission. TC and VB then you will need an upgraded flexplate. Then you will need a billet input shaft/drum and so on. Sometimes it dosen't make any since to even touch it, if it wasn't for that darn TC I wouldn't even consider it at all.
Old Feb 21, 2007 | 03:27 PM
DBLR's Avatar
As per several rebuilders you should change both the filter and fluid every 30K as listed under Sched B. The filter for your trans is not all that costly to not change it every 30K. As for as flushing or band adjustment I'll stay out of that can of worms.
Old Apr 25, 2007 | 10:58 PM
usmcduncan001's Avatar
i put a manual lock up switch on my 01 2500 QUAD CAB. CURED ALL PROBLEMS WITH HUNTING BETWEEN O/D AND 3RD, OR IN OR OUT OF LOCK UP. THEY MAKE A TCC FOR THESE BUT THEY COST OVER 4 HUNDRED. MINE COST 5 BUCKS WORTH OF MATIERIAL, AND ABOUT IN HOUR INSTALLATION
Old Apr 26, 2007 | 09:41 AM
RunninLean's Avatar
Actually your hitting lock up at 50 your in OD at around 42.
Old Apr 26, 2007 | 09:49 AM
RunninLean's Avatar
Originally Posted by goose2
To me that is the worst part of the dodge trucks. Its the auto tranny. Its to bad that they couldn't build a tranny that had a smoother shift. Mine used to really bang into gear from 1st to 2nd. That was the main reason for me getting rid of it. The truck never failed me. The tranny just drove me nuts. Most of it was not the trucks fault. It was me just being a picky edited by admin. Who knows, maybe we will have to check out the new 6 speeds.
Thinking like this is why we have so many tranny issues! Softer shifts means more slop and more slipping and leaves you with faster wear and less transfer of power. We have to many people driving these trucks wanting them to ride and drive like a mini van!!!
Old May 5, 2007 | 12:23 AM
belgianmagic's Avatar
THEY ARE TRUCKS ...MASH on the skinny peddle !
No problems w/mine Use tow mode til I need OD
tbelue
Aug 22, 2007 08:16 PM
kev94mx
Nov 8, 2006 11:16 PM
ATVConnection
Mar 21, 2004 09:15 AM
jlbota
Mar 15, 2004 10:56 PM
cad14man
Oct 22, 2003 05:44 PM
