Tranny question
Old Oct 20, 2009 | 07:30 AM
snowball's Avatar
Tranny question
152000 miles trouble free and the tranny finally started to act strange. It seems to not want to shift until 25 mph and then goes into 3rd and won't go to 4th. was working great up till Sat after dropping my trailer. No 2nd and no 4th, still pulls good but no TC lock up. Anybody have any ideas. I have search but nothing really to compare to. Thanks. Niels
Read more: http://www.dieselbombers.com/5-9-lit...#ixzz0UTjBDdNb
Old Oct 20, 2009 | 09:53 AM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
sounds electrical. Start with a can of contact cleaner and hit all three connectors on the passenger side firewall area. Disconnect your batteries first and then give those three conns a good cleaning and plug in several times over to make good contact. If it fixes most of your problem go on to the trans plugs and do the same.
I speak from experience. Look up some of my past posts on the subject.
good luck.
db
Old Oct 20, 2009 | 10:30 AM
no_6_oh_no's Avatar
He doesn't have any connectors on the passenger side firewall that control the trans. The TCM is integrated into the ECU.
First thing is to check for codes. Sounds like the trans is in limp mode and you should have some codes to go by.
Old Oct 20, 2009 | 10:42 AM
cdennyb's Avatar
really? maybe he should go look. There is a PCM and the ECM from the engine block runs into it with a series of cables. The Throttle control APPS also runs into it. Maybe the 04 I saw had 03 wiring in it then.
db
Old Oct 20, 2009 | 10:48 AM
no_6_oh_no's Avatar
db
The 03's still had the JTECH\NGC controller with the PCM and TCM modules in it. The MY 04 deleted that controller because of the issues with it and moved all the functions into the ECU. Every 04 I have looked at has been without the the seperate PCM and the FSM lists it that way also.
It would not be unusual to have a very early 04 that was really a left over 03 that still had that setup. At the MY switch over anything is possible.
Old Oct 20, 2009 | 04:08 PM
snowball's Avatar
No codes come up, and I will checkany connections. It all happened suddenly with no previous symtoms. Thanks.
Old Oct 22, 2009 | 06:05 PM
snowball's Avatar
Used some seafoam trans cleaner,flushed it out, drpopped the pan and no signs of wear indicated. Went for a drive today and everthing came back normal. Putting new GPS in tommorrow.
Black Dog
Dec 3, 2009 08:18 PM
high bid
Aug 2, 2007 06:08 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
mikie1234
Dec 25, 2004 12:54 AM
silverram323
24
Nov 9, 2003 07:48 PM
