Tranny Auto Or Manual
Old Feb 17, 2005 | 11:03 AM
mitchmp's Avatar
NEWBE, FIRST TRUCK!
IM ABOUT TO ORDER A 3500 DIESEL QUAD CAB LB SRW.CAN YOU ADVISE PROS AND CONS TO THE AUTO 4 SPEED AND THE MANUAL 6 SPEED. IM LEANING TOWARDS THE SIX.
Old Feb 17, 2005 | 11:15 AM
MedicShawn's Avatar
Just make sure you like rowing the gears. That close ratio 6 speed can be labor intensive. I like mine, just make sure you know what you're getting.
Old Feb 17, 2005 | 11:19 AM
bigblock2stroke's Avatar
You can always skip a couple gears (example 2nd, 4th, 6th).
Old Feb 17, 2005 | 01:17 PM
tankeryanker's Avatar
If your going to be towing I would go with the manual for sure. Other wise expect to do some tranny upgrades down the road.
Old Feb 17, 2005 | 03:46 PM
Hemi Cat's Avatar
The decision is mostly personal preference and what you are going to do with it. Towing the manuals are superior, and give more economy.
Old Feb 17, 2005 | 05:56 PM
bluepp's Avatar
And dont overlook the fact you CANT lockout overdrive on the 2005 auto. Not being able to lockout overdrive when needed is not good for towing .
Old Feb 18, 2005 | 04:55 PM
mitchmp's Avatar
THANKS GUYS, I THINK ILL STICK TO THE STICK!
Old Feb 18, 2005 | 05:49 PM
bluepp's Avatar
There upgrading the 6 speed , make sure you get the latest. And if I'm not mistaken they had two 6 speeds available , one was rated heavy duty. But there upgrading to a new Mercadies 6 speed . I believe it Mersadies. Check it out get the latest.
Old Feb 18, 2005 | 05:54 PM
bluepp's Avatar
The new 6 speed is a G56--Mercedes Benz
v8440's Avatar
OK! STICK TO THE CAPS LOCK TOO!
(I'm just messing with you, not trying to be an for real.)
Old Feb 18, 2005 | 05:55 PM
Hounddog's Avatar
Only ONE six speed now.Its a G56 made by Damiler.There are some leftover NV5600.To differant beasts.Also the dual mass flywheel is being used with the G56.It nor the trans are proven yet with the Cummin.
Old Feb 18, 2005 | 08:29 PM
mitchmp's Avatar
Sorry about the caps. i allways forget that!
THANKS ALL!
Diesel4blood
Jul 21, 2014 04:23 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
Diezelgal
Dec 9, 2004 04:25 PM
antknee
Jun 19, 2003 07:33 AM
