towing MPG's
towing MPG's
I just got back from the dunes. I was towing a 18' trailer with some quads. About 3k lbs. averaging about 70mph.. I only was getting about 12 mpg. Is this normal? I asume it would be better. I would hate to see the milage with a 12k trailer.
wind has alot to do w/ mileage i can tow on bone stock setting....matter fact nothing even hooked up 10k behind my truck and get the same as hauling my buddies 2800# trailer thats 12' tall and catches a crap load of wind...and i got 10.5-11mpg
I pull campers of about every shape and size and i get 11.5 to 12 all the time running 65 to 70. I have tryed about everything and nothing seems to work to bring it up. I can get 13 to 13.5 if i run 50 to 55. But i cant stand to run that slow and with everybody else running 85 on todays highways, you can get yourself killed by driving that slow.
I hope that helps
I hope that helps
9.3 to 9.7 towing flat faced enclosed car trailer (8 - 10K depending car) at 78ish mph. Low 10s with a 8.75K tag camper at same speeds) I know I should go slower but sometimes I am not so bright. BTW I live abd tow above 5000 ft.
Wish it was better but past big block gasser would not pull the same trailer at speed and speed would drop quickly on ANY grade and got 6 to 6.5 mpg under the same conditions. Very glad I have the Cummins now!
Hope it helps.
Hope it helps.
10-13 is NORMAL while towing just about any weight TT or 5VR that has any height to it. It doesn't matter what it weighs, it's the wind resistance tha tdoes you in.
Just remember that you can tow a 100lb barn door(against the wind of course) and probably get worse mpgs thatn if yo were towing a 10klb cement pipe.
bngcustoms
45
Jun 20, 2009 06:55 PM
bigfish5
Sep 19, 2006 12:56 AM
