torque converter lockup
Old Sep 19, 2006 | 03:13 PM
mitchkim's Avatar
i believe the tc lockup is controlled electroically
my locks up at 28mph in 2nd and 48mph in 3rd
are there any programs that will get the converter to lockup sooner
or do they have anything where i can control the lockup myself
my truck is stock
the lockup in 2nd is ok but i would would like to change it to lock up sooner in 3rd
Old Sep 19, 2006 | 04:57 PM
goose2's Avatar
The only thing that I don't like when the tq converter locks up in 2nd at 20-30 mph is under very lite throttle there is a very loud "clunk" sometimes. Not to highjack the thread, but if anybody knows how to stop this please chime in. Now back to your question. Someone on here hooked up a switch to control the lockup manually. If you do a search on here you will find out how to do it.
Old Sep 19, 2006 | 05:24 PM
Casket Man's Avatar
I don't want to start a war here, but I do know SP diesel has a converter lockup controller. You should give them a call and ask about it because I'm sure it is still to new to post on the website.
Old Sep 19, 2006 | 05:29 PM
estesbubba's Avatar
do the 06's lock up in 2nd and 3rd? it seems mine locks up in 4th in "normal" mode at 48mph and locks up in 3rd in 'tow/haul" mode.
Old Sep 19, 2006 | 05:42 PM
ptgarcia's Avatar
They lockup in 2nd and 3rd only when in tow/haul mode. Otherwise its 4th only.
Old Sep 19, 2006 | 08:38 PM
mitchkim's Avatar
mine is an 03 and the way i get it to lock in 2nd and 3rd is to shift it manually on the coloumn
the 03 does not have the tow/haul mode
Old Dec 22, 2006 | 08:10 PM
chucktuna's Avatar
After searching many posts, this seems to be the most likely candidate for my question(s) ......
I do most of my 18 mile commute between home and work on 45 to 50 mph roads! So, I end up just short of the speed in which my trans eventually locks up its torqe converter, seems to be about 52 mph with my size 295 Nitos, with the Smarty correction. (was about 50 with the stock tires)
Now that I've got a trans temp guage, I'm even more concerned about getting in locked up overdrive sooner. About 30 degrees cooler!
When it does lock up, I can slow back down to almost 42- 43 mph while keeping it locked up....especially with the cruise control.
So, my question, is this about the normal speed for the rest of you?
Is there any way to get it into OD lock sooner?
Chuck
Old Dec 23, 2006 | 08:13 AM
T & T's Avatar
https://www.dieseltruckresource.com/...+manual+lockup
this link is how to make a lockup switch so you can lock any time you want.
Old Dec 23, 2006 | 08:48 AM
bluebull's Avatar
In regular mode on a 03-04 truck = 1 - 2 - 3 - lockup - unlock then shift to 4 - lockup.
T/H mode or OD off = 1 - 2 - 3 - lockup.
You can control shifts manually with lever in T/H mode = 1 - shift to second - 2 - lockup - shift to third - 3 - lockup.
You can also use the shift pattern in backwards pattern slowing down for engine brakeing effect.
The 05 trucks will do the same only they do not have a OD off position.
The 06 trucks will do the same thing as a 03-04 truck except they have a OD off position and T/H mode.
T/H = 1 - 2 - 3 - lockup - unlock shift to 4 - lockup.
T/H manually control shifts with lever = 1 - shift to second - 2 - lockup - manual shift to third - 3 - lockup - manual shift to 4th - 4 - lockup.
Now my brain is mush, hope some one can understand the patterns.
Old Dec 23, 2006 | 01:22 PM
chucktuna's Avatar
Thanks for the info guys!
Looks like a trip to Radio Shack
chuck
Old Dec 25, 2006 | 08:15 AM
bluepp's Avatar
Good explanation Bluebull, Thats just how they work. With the 06 being the best to date. Hopefuly the new 68re will be better yet. Not to many people know how to run a auto. They just let it do its thing and then wonder why they burn out. You gotta drive the truck, keep trans in the right gear for the situation and torque converter locked .
Old Dec 25, 2006 | 01:47 PM
Jeeptug's Avatar
...clarify this for me...('06)
If I'm in T/H mode, I can manually shift to "2" and it will lock-up in 2nd? This will be handy on those long steep grades towing 12k.
Old Dec 25, 2006 | 05:18 PM
bluebull's Avatar
You are correct, but.
If increasing speed will work as described, lockup at appropriate speed.
If decreasing speed you will have to shift to 2nd manually then blip the throttle to get it to lock. It will unlock automatically when speeds get low enough, I think around 22 MPH.
93dieselZak
Jun 16, 2011 06:10 PM
tomh
Feb 14, 2005 08:26 PM
tractor-man
Oct 13, 2004 02:54 PM
Jambbii
Apr 27, 2004 02:31 PM
Jambbii
Oct 18, 2003 07:08 PM
