tire wear
tire wear
I put a 2" leveling kit on the truck and now it pulls to the right slightly and the tires are cupping bad. I had an alignment done and everything is in spec. What can I do to make it better?
First time was local tire store. In spec. Second time I did at the military auto shop. Tech was there and we did it together. You can move the axle forward and backward on each side (not sure if camber or caster) but you can not tilt the tires IE: / \ This is looking at the wheels from the front or rear. Not birds eye view. He said it cant be adjusted. I was at .45degree. Said everything is in spec. It doesnt feel right. I had this on my 02 with no probs. I put in a metal 2" spacer. That is all that was in the kit.
Dave88LX
14
Sep 1, 2011 11:36 AM
