Timing Issue?
Old Jan 24, 2010 | 01:26 PM
GWSaddles's Avatar
Timing Issue?
I just purchased a used 06 3500, 5.9L, G56 with PacBrake and 5" exhaust. It has been a hard starter even in mild (40*) temperatures. Today I was while idling I stepped on the accelerator and pushed it up to 2600 RPMs. At that RPM it started to miss and run rough. Does anyone think I may have a timing issue? If not what other suggestions are there? Thanks.
Old Jan 24, 2010 | 02:01 PM
littlebigtruck's Avatar
I don't think it's in your timing, I would start by checking your fuel filter and your fuel pressure. Hope this helps you, and would be nice if it was something simple for a change-right?
Old Jan 24, 2010 | 02:09 PM
AH64ID's Avatar
I agree either fuel filter or lift pump.
Old Jan 24, 2010 | 06:41 PM
NickBeek's Avatar
On an '06 I would bet you have a bad injector or 6. I had problems with mine starting at about 20K miles. I finally convinced the dealer to replace all 6 with the updated parts around 40K miles and have been great since. I am now at 123K miles.
Old Jan 24, 2010 | 11:10 PM
SNOWJUNKIE's Avatar
bad injectors did similar things on mine too
Old Jan 24, 2010 | 11:42 PM
Spooler's Avatar
Yeap, either a clogged fuel filter or bad injector or 6 as stated. Make sure you put a Fleetguard filter in just incase you have a warranty visit. Make sure it is the 7 Micron filter.
Old Jan 25, 2010 | 12:04 PM
GWSaddles's Avatar
Took the truck to the local Dodge dealership today. After their inspection they say fuel pressure is fine but they detect one bad injector. They are giving me 6 new ones (engine still under warranty). Hope this does the trick. Thanks to all for your insight.
Old Jan 25, 2010 | 12:50 PM
1-2-3's Avatar
Just a plain ole guy
I recommend you buy a lottery ticket right away
Old Jan 25, 2010 | 01:01 PM
cbrahs's Avatar
no doubt! I have been told by both dealers in this town that they would ONLY replace the bad injector. Getting authorized by dodge to replace all 6 was not going to happen. COUNT YOUR BLESSINGS and head to Vegas!
Old Jan 28, 2010 | 10:09 AM
GWSaddles's Avatar
Well, I just picked up my truck at the dealer. 6 new injectors and it was 8 degrees when I went out to their parking lot and fired the truck right up without it being plugged in. All covered by warranty and no arguments. I was very pleased with the service at Bob Brady Dodge in Decatur, IL.
Old Jan 28, 2010 | 10:50 AM
megacabdad's Avatar
Good stuff!
dan123dbl
Feb 13, 2015 05:47 PM
SportTruck
Sep 13, 2005 07:32 AM
MNMSPARKY
Apr 3, 2005 01:18 AM
DDysput
May 5, 2004 07:44 AM
