DTR braintrust ? on '07 5.9's
Old Jan 23, 2010 | 05:54 AM
pull-do's Avatar
What's the particulars on the 07 5.9's,,,,, any problems or are the earlier 3rd generations better,,,, mainly talking fuel mileage and dependability.
Lost my truck in my signature line two weeks ago,,,, totaled out by a uninsured driver.
Any info appreciated to help me make this choice.
Old Jan 23, 2010 | 08:50 AM
Dan_K's Avatar
Can't go wrong with the last year of the 5.9.
I had an 05 and now an 07 and love them both. Drove 500 miles round trip last week taking my wife to the airport and averaged over 20 mpg hand calcd in a 3500 single rear wheel using 4x4 in snow conditions for 60 miles each way. There is no such thing as a 2010 truck that will compare to this.
Old Jan 23, 2010 | 09:06 AM
nedz19's Avatar
I love my 07. i generally get 19 to 20 mpg but i put bigger tires on. with the stock wheels and tires i was getting 24 to 25 mpg.
Old Jan 23, 2010 | 09:37 AM
Skyd Ram's Avatar
07 added the ugly taillights IMHO although some guy like them. It also added the better stain resistant fabric to the seats. The 06-07's tend to run higher egt's stock than the 04.5-05's although that is easilly fixed with a Smarty or Smrty JR. 06 seems to be the year where the front end and drivleline components started to see a drop in quality as the u-joints/balljoints/unit bearings etc. seem to go out quicker.
BTW,
I love my 07 5.9 Mega and found the last one in a 3 state area when I started looking for a new truack a few years ago.
Old Jan 23, 2010 | 04:43 PM
Utundra's Avatar
No complaints with my '07. Mileage is about 16 around town, maybe 18 on the highway if I keep it at 65.
Had the new front steering parts replaced under a TSB before the local Dodge dealer closed. Then there was the subsequent recall on the new steering parts and that was also done under warranty, though at a dealer about 40 miles further away.
This is by far my favorite pickup I have owned, first Dodge, but number 10 overall I think.
Old Jan 23, 2010 | 05:20 PM
Danderson's Avatar
Great truck. If you can score one of these trucks that get 20+ mpg consider yourself lucky. The vast majority of them get 14-18 mpg. That's still great for a heavy truck w/325 hp.
Old Jan 23, 2010 | 05:33 PM
AH64ID's Avatar
On your overhead I presume.
Old Jan 23, 2010 | 05:54 PM
sotex's Avatar
i bought my o4 july 08 with 56000 miles it has ben geting 14/16 mpg not mutch difrence on hyway usuly towing some sort of trailer. replaced water pump now having trans hunting first to second then back agin.selonid andv/b i belive is the problem.changing to amsol trans fluid and new filter.will fix hunting problem then.98000 miles now .
Old Jan 25, 2010 | 08:23 PM
nedz19's Avatar
Yes. i figure it when i fill also and its generally pretty close to that also. and my speedo is still pretty well right on
Old Jan 26, 2010 | 10:01 AM
Grit Dog's Avatar
I'd pretty much throw the bs flag on 24-25mg, except downhill, but babying it around on state highways back east (55 saves lives) I was pulling low 20's, so might be possible if driven verrrrry carefullllly.
FWIW, my overhead has never been too far off. 1mpg or less too high. With the 285s (no speedo recal, still thinks it's running 31" tires (265s)) the speedo is a little slow on the hiway, but the overhead mileage is close now.
Old Jan 26, 2010 | 10:03 AM
Grit Dog's Avatar
No problems on my 07 so far, 55k mi only though, but check out colo-dirtbikers truck. 06 with 275kmi + and he hasn't cracked open anything on the drivetrain except for a clutch or 2 and hauls RVs.
Old Jan 26, 2010 | 05:45 PM
DaveB.inVa's Avatar
If you're looking for an 07 look for the AE G-56. It has the higher OD ratio.
After the mods below I get about 18.5 around town hand calculated.
If I take a long drive and keep the speed around 55 I can get just a hair over 20 mpg hand calculated.
I've found I can get the overhead closer to my calculations if I reset the overhead at each fillup. Before I never reset it and would get errors between 9 to 14% (I've got a spreadsheet with that and all other sorts of stuff in it). Each time I reset it the error is usually between 3 to 5%.
Old Jan 26, 2010 | 07:05 PM
nedz19's Avatar
Could the fact that you are almost 6000 feet higher than me have anything to do with that?
Old Jan 26, 2010 | 07:08 PM
AH64ID's Avatar
Wink
Nope... 24-25 just doesn't happen on 04.5+ trucks.. unless your talking 55 mph for an enitre tank, downhill at sealevel.
My overhead has said over 23-25 before... actual tanks were 18-19.5
Old Jan 27, 2010 | 08:15 AM
isb07's Avatar
i like my 07 5.9. ive never driven a 6.7 but im happy. 35k miles just ball joints and front u-joints so far have gone bad. milage is ok empty around town 15 and and 17 -19 hwy going 60-65. alot lower numbers in the winter though.
