Time for rotors
Old Nov 18, 2009 | 05:11 PM
slickr1's Avatar
Time for rotors
2006 Ram, looking for some input n new rotors. Just purchased th oem pads, but the rotors have several good groves in them.
Thanks
Old Nov 18, 2009 | 07:49 PM
.boB's Avatar
If they can't be cut, go down to NAPA/Autozone/whatever and get quality stock replacements
Old Nov 18, 2009 | 08:08 PM
CoastalDav's Avatar
Just curious, how many miles on the rotors? (06)
I used NAPA (chinese) on my last truck (2000 3500) with warner extreme duty pads. 95,000 miles before the right caliper started to stick. Still had 1/4" pad on left side and 1/8" on right inside. Changed calipers and pads.
Dave
Old Nov 19, 2009 | 08:20 AM
slickr1's Avatar
I have 52k, the rear have some groves. I am still runing the oem.
Old Nov 19, 2009 | 09:31 AM
psd1's Avatar
Yikes, only 52K. Are you the original owner, tow alot?
Pull em off and have them turned...slap your new pads on and your back in business!
Old Nov 19, 2009 | 12:25 PM
jfdid's Avatar
If you're can't be turned($20 per rotor), I'd check on ebay. I just bought a set of 4 rotors and 2 sets of pads all for $510 to my door. Super cheap compared to the $470 I spent only on rears last year. The guys I bought from were out of Quebec, Canada. Good luck. Remember to check your sliders and boots...grease and replace as necessary.
Old Nov 19, 2009 | 01:07 PM
slickr1's Avatar
Thanks guys I did check into the deals on e-bay. I just did know how good they were, I am the only owner and I tow my 5k boat and a trailer with 4 wheelers to Mo. turkey huning from Pa. But I have never had a real load I guess. I might have them turned and see how that works out, again thanks for the info..
Old Nov 19, 2009 | 02:28 PM
jimbo486's Avatar
if you're looking for aftermarket, try SSBC. they won't be cheap (approx. $150 a piece) but they're drilled and slotted. not sure about multiple piston calipers for the 3rd gens, but they don't make any for my '90. only rotors and pads are available for 1st gens.
Old Nov 19, 2009 | 02:40 PM
Danderson's Avatar
Drilled and slotted rotors didn't work out for me on my '98.5. 9% of the clamping surface was removed by the machining. I went back to NAPA premium(not Chinese at the time) stockers and regained my already shaky stock braking performance. I think just the slotted might be a good compromise. I researched the cryo- treated rotors also. Very spendy,but they might be the last rotors you have to buy for awhile.
Old Nov 19, 2009 | 06:44 PM
psd1's Avatar
Good luck, I would look into why they need to be replaced so early...or maybe change your driving habits a bit!
Old Nov 19, 2009 | 07:01 PM
slickr1's Avatar
I will look into what you all have posted. And my driving habits are very easy, if I want to go fast I get on my r1. While rotating the tires I was checkin the pads and rotors, I discovered both rear have groves on the inside.
I appeciate all the input. thank you for the help...
flynhigh205
14
Dec 24, 2011 12:38 AM
04ctd
Aug 3, 2007 04:19 AM
k_butz
Feb 23, 2007 03:42 PM
taken5875
20
Jan 11, 2007 09:38 PM
