Tans fluid leaking from neutral safety switch
Old Nov 20, 2012 | 09:07 AM
TenSixx's Avatar
I've been checking out this site for while now and thanks to members posts I've put a 2'' level kit, and some Bilstein 5100's on the truck.
Anyway, I've had the truck for just over a month and noticed I had a transmission leak because the bottom of the pan was soaked. Changed the pan gasket and the leak still remained. Long story short the leak was identified and was coming from the neutral safety switch. Replaced the switch and the leak went away... at least for a couple days. I definitely fixed the leak, but the plug was a little wet, so I cleaned it all up and it just got wet again.
I just replaced the plug for the second time yesterday hoping it was just a bad part. Could it be from parking on an incline with the front end slightly up? The leak appears to be coming from the switch itself around the crimps.
All help is appreciated! 2005 Ram 2500 5.9L 4X4 111,700mi
Old Nov 20, 2012 | 07:36 PM
06RAM2500's Avatar
Fluid level ok, not over filled?
Old Nov 20, 2012 | 07:40 PM
TenSixx's Avatar
Shows just above the full line. Overfill will cause fluid to leak from the neutral safety?
Old Nov 20, 2012 | 07:45 PM
TenSixx's Avatar
That is checking it while the truck is running if that matters.
Old Nov 21, 2012 | 05:59 PM
TenSixx's Avatar
Wiped the new switch down but once the truck gets cold fluid appears on the face of the switch. Any ideas? At a loss.
Old Nov 27, 2012 | 02:33 PM
goalie2's Avatar
did the sw come with an o ring?If not that could be it.Or possible the sw is defective or not seated all the way(had issue with mine had to nut and bolt it as the case screw mount got stripped(very weak aluminum)) but mine hasnt leaked one bit.
lovin1stgens
Aug 31, 2018 09:49 PM
uncle ed
Jun 25, 2007 10:23 AM
Stamey
Feb 23, 2005 07:35 PM
spunbearing
Dec 23, 2004 01:44 PM
