Adjust the Neutral Safety Switch on an AT?
Old Feb 22, 2005 | 09:58 PM
Stamey's Avatar
My reverse lights won't stay on unless I pull up on the shifter. I figure I should adjut the neutral safety switch, as historically, on other vehicles, I have been able to do this to fix the problem.
My neutral part of the switch works properly. Truck starts fine in Park or Neutral. I have looked at what I believe is the switch, in the tranny case toward the rear of the shifter linkage, but don't know what to adjust, or if it is possible. It appears to be like a sending unit, and screwed tight into the tranny case. I can't see a way to adjust it.
Is this one of those parts you just have to replace, or can it be adusted?
Thanks,
Chris
Old Feb 22, 2005 | 11:08 PM
infidel's Avatar
There is no adjustment except the linkage to make the starter engage in only P or N. If your starting part of the system is working ok the problem is the switch.
Old Feb 23, 2005 | 08:04 AM
V Baker's Avatar
Had the same problem,replaced switch,solved problem.Just be ready to loose about a quart fluid,unless you are really fast.Verry easy job.don't forget the metal washer,or it "will" leak.
Old Feb 23, 2005 | 07:35 PM
Stamey's Avatar
Thanks for the info. I'll pick up one tomorrow.
Chris
lovin1stgens
Aug 31, 2018 09:49 PM
tyler93
Jun 28, 2012 10:43 PM
uncle ed
Jun 25, 2007 10:23 AM
spunbearing
Dec 23, 2004 01:44 PM
