Surging on Cruise, and backfire?
Old Aug 20, 2010 | 11:07 AM
RedRewster's Avatar
Thread about the '07 5.9 in my sig.
The issue is fuel system related. On cruise control my truck surges unless there is some load(i.e.- going up an overpass). The other symptom is what I would call a backfire at idol. I can stand outside the truck and hear it. I'm not real familiar with the fuel system, but have a basic understanding and have my own hypothesis.
Things to know-
Fuel Filter is good
Had symptom before Dr. P installed.
Cruise surging was not as bad before DP installed.
100k on the truck.
The "backfire" can be described as pooof noise
Old Aug 20, 2010 | 11:17 AM
madhat's Avatar
Administrator/Jarhead
Do you have any codes?
https://www.dieseltruckresource.com/...s-t224833.html
vzarich's Avatar
Based on the symptoms you are describing I would check valve adjustment. It sounds like you may have a tight or burnt intake valve.
Old Aug 20, 2010 | 01:46 PM
storx's Avatar
my fca was surging a little at cruise... it was more noticed when i would rev up and let off the pedal and it would hold rpms for a few seconds longer then normal..
Old Aug 20, 2010 | 06:25 PM
RedRewster's Avatar
no codes whatsoever.
FCA? Enlighten me please, when it surges the most is under normal cruising load, straight, flat highway, 65 mph.
I'm not sure what to check for on the valves. I'm sure I can figure it out with a lil' help from the internet. I've just never had to mess with a Cummins Head before.
Old Aug 20, 2010 | 06:31 PM
madhat's Avatar
FCA= Fuel Control Actuator. On the CP3.
Adjusting valves: http://dodgeforum.com/forum/dodge-cu...tment-diy.html
I'm agreeing with the valves.
Old Aug 20, 2010 | 06:57 PM
RedRewster's Avatar
If the actuator is cheap enough I'll replace it anyway. Thnx for the link, and all the help. I'll update probably Monday after I've had a chance to get into it. I was originally thinking about an injector actuator being the problem.
Old Aug 20, 2010 | 06:59 PM
storx's Avatar
you might want to invest in the arson kit while your at it.. since the FCA is in that kit.. my FCA was $153 from cummins.. sucked aparently the days of them being $90 is long gone.
Optimus
Jun 15, 2009 09:31 PM
hoehand
May 30, 2006 01:10 PM
rjordan
May 16, 2004 02:51 PM
dfwrepo1
Apr 26, 2004 09:49 PM
aklabs
Apr 2, 2004 01:05 PM
