Surge At Full stop
Old Jul 11, 2007 | 10:30 PM
Lionhart75's Avatar
Surge At Full stop
Hi i am having a recently new problem with my truck. On occasion whe i get off the highway or even when in traffic and come to a full stop the whole truck will surge forward rithmicly. almost like the tc isnt disengaging or somthing like that. Anyway i am concerned and want to know if this is a precurser to a larger failure. Also with the edge can i leave it installed when i take my truck into the dealer or should i pull it out?
Old Jul 11, 2007 | 10:55 PM
vzdude's Avatar
DTR's 'Go to Guy'
More than likely it is the transmission governor pressure solenoid or transducer. They aren't reading all the way to 0 and stays in 2nd. Then when they do it downshifts to 1st gear. Very common problem. That's the first thing I would check at least. Well......any codes? That's the easiest.
Old Jul 11, 2007 | 11:12 PM
Lionhart75's Avatar
No codes yet. I would assume that this is a dealer fix?
Old Jul 11, 2007 | 11:16 PM
vzdude's Avatar
DTR's 'Go to Guy'
Fill out your sig in the User CP and it will let us know what you drive. I was assuming it was an auto. If its under warranty yes. If your out of warranty you can do it yourself in an hour or so. Probably about 150 bucks or so for the parts and a new filter and pan gasket. You'll need fluid too! Have several rags around. Did some today in about 45 minutes with a hoist and air tools!
Old Jul 11, 2007 | 11:38 PM
Lionhart75's Avatar
It is still under warranty so i will make an appoitment. anyway should i remove the edge for my own good when i send it in?
Old Jul 12, 2007 | 06:41 AM
vzdude's Avatar
DTR's 'Go to Guy'
I would unless you know for a fact that the dealer is mod friendly! Good luck.
Andy
12valvewagon91
Feb 15, 2014 08:50 PM
johnsjas
Apr 8, 2008 06:24 PM
rootremblay
Sep 4, 2007 10:24 PM
slivertruck
25
Nov 8, 2006 08:35 PM
royta
Nov 6, 2006 08:19 AM
