Strange noise
Old Feb 17, 2012 | 09:15 AM
Reelay's Avatar
Strange noise
When shifitng gears while throttling up a strange noise is heard between gears. It is coming from under the hood around the turbo area. Is it the turbo spooling up or another problem? Happens mostly when I am putting the go pedal down like onto a freeway ramp or pulling my trailer. When I back off the RPMs it will go away. I have a programer installed {Edge W/Attitude} haven't tried to get the noise to come back in stock mode. Any input would be appreciated, thanks...
Old Feb 17, 2012 | 09:23 AM
jhenson's Avatar
Possible boost leak. Check your hoses and make sure none of them are torn. You will only hear a boost leak upon acceleration.....which you have described.
Old Feb 17, 2012 | 09:37 AM
Reelay's Avatar
Thanks for the tip. I will be doing that first thing when I get a chance. If it is not that do you or anyone else have any other suggestions what it might be? Sure is irratating..
Old Feb 18, 2012 | 02:28 PM
Reelay's Avatar
Went out to check the clamps and hoses on the turbo and there were no holes in the hoses and retightened the already tight clamps. To my suprise the noise went away. Man those clamps were tight but the are really tight now. I am going to switch the stock worm gear clamps over to "T" bolt clamps which will hold better. Thanks for the tip....
Old Feb 20, 2012 | 01:23 PM
jhenson's Avatar
You betcha. We are all here to help one another out. Glad ya got it fixed.
torq
19
Dec 30, 2005 05:59 PM
heavyg
Jun 24, 2003 07:43 AM
DarrellB
Mar 3, 2003 06:26 PM
Gregor
Dec 3, 2002 12:18 AM
heavyg
Oct 25, 2002 05:06 AM
