Stock Gears?
Old Nov 2, 2008 | 07:20 AM
Bowser50's Avatar
Question Stock Gears?
Does anyone know what the stock gearing in the rear end of an 04 2500 is? I have a 6 spd manual, QCSB 4X4 with the H.O for 04 305/555 if that helps anyone.
Old Nov 2, 2008 | 07:47 AM
Dartsport's Avatar
3.73 or 4.10 Easiest is to look on the sticker under the hood, or look at the tag on the rear covers. The tag is on one of the cover bolts........
98whitelightnin's Avatar
I think they have 3.73 and 4.10 rearends. There should be a tag on the cover held on by a cover bolt that will say.
Old Nov 2, 2008 | 08:49 AM
NickBeek's Avatar
The AAM axles on the 3rg gens don't have tags on them. But the '04 should have a sticker or tag in the glove box that will show axle ratio.
Old Nov 2, 2008 | 10:30 AM
Bowser50's Avatar
yeah I don't have the stickers in the glove box or on the axle where else could I find the info. I am unable to look right now too, I am deployed so if anyone could help I would be greatful. thanks.
Old Nov 2, 2008 | 10:39 AM
Ram Daddy's Avatar
Might have to have someone call the dealer with the VIN...they should be able to tell you.
Old Nov 2, 2008 | 12:11 PM
NickBeek's Avatar
Yup, have someone call a dealer with the VIN and they can run you a build sheet with all info about the truck. Also if you can remember what RPM your turning at 60 mph I bet someone can chime in with their ratio which should help you.
BTW, thank you for sacrificing your time and safety for our freedom!
Old Nov 2, 2008 | 12:51 PM
Bowser50's Avatar
@55mph I hit about 1600 RPM in 6th gear, in 5th gear 55mph is @2900 RPM and for 60 mph in 6th gear is a little closer to 1800 RPM. From what I can remember.
Old Nov 3, 2008 | 12:04 AM
1normy's Avatar
I am thinking that you have a 3.73. I have an 04.5 with a nv 5600/3.73 and in 6th gear at 60 mph I run about 1800 rpms.
Old Nov 3, 2008 | 01:48 AM
Bowser50's Avatar
What Kind of gears could I step up to if I wanted some more acceleration?
Old Nov 3, 2008 | 06:46 AM
Ram Daddy's Avatar
Exclamation
I wouldn`t even consider a gear swap , if I were you... for less money you could buy ANY chip/programmer and get way better results than a gear swap.
If you really wanted to do it 4.56s are the lowest you can get...best for acceleration...worst for anything over 45mph with stock tires
BigJohnston
20
Jul 14, 2019 10:58 AM
Roarinbear
Dec 27, 2009 09:44 PM
93beater
Feb 28, 2007 09:28 AM
Turbodude
Jan 4, 2006 09:13 PM
walexa
30
Apr 8, 2005 10:26 AM
