Stock Fuel filter housing ??
Old Oct 1, 2007 | 09:06 PM
JP-4.5's Avatar
I added a pre-filter, GDP fuel pump and the 2 micron filter to my truck last fall. Living in the Northeast I kept my stock filter housing in the loop to have the fuel heated in the winter.
My setup is pre-filter > GDP > stock filter housing > 2 micron > CP3.
My question is can I use the stock filter housing without a filter in it? I want to keep in in the loop only for the heating properties. The 2 micron filter is larger and much easier to replace where I have it mounted. It costs less than the stock filter.
Thoughts? Has anyone ran without a filter in the housing?
Thanks, Jeff
Old Oct 1, 2007 | 09:49 PM
jkitterman's Avatar
If you remove the stock filter, you will have no water separator unless your pre filter does that.
Old Oct 2, 2007 | 12:31 AM
ptgarcia's Avatar
I run both the stock filter and the 2-micron spin on. I kind of use the 10-micron factory filter as a pre-filter. And it's also needed for water separation like jkitterman already pointed out.
Old Oct 2, 2007 | 05:38 AM
JP-4.5's Avatar
I will definately keep the filter for the water seperator function. Need to state in the 4 years I have had the truck I have yet to see any noticable water when changing the factory filter. I presently monitor fuel pressure right before the CP3. When I start to see pressure dropping it can be any 1 of 3 filters. I usually change the pre-filter 1st. Then factory.. then 2 Micron. I check pressure between each filter change to see if it was that filter causing the pressure drop. Maybe I need to add 2 more fuel pressure sending units and a 3 position switch so I can determine which filter is at fault.
Thanks, Jeff
Old Oct 2, 2007 | 09:46 AM
raycarlson's Avatar
they're cheap just change them all.why spend 35K on a truck and then fret over spending 20dollars on filters?
Old Oct 9, 2007 | 12:44 PM
JP-4.5's Avatar
Not being cheap... Just don't want to be wasting my hard earned money.
If I can change the pre-filter 3-4 times without needing to change the other filters the money saved grows quickly. The last thing I want to do is throw away a 20% full filter for no reason. If someone was giving me the filters for free I still would not want to change them if they are not used.
Factory filter $12, 2 Micron $11, Pre-filter $5
Pre filter is just to keep the big stuff from clogging the GDP pump up. GDP recommended it. The 2 micron filter is very large and I would think having the factory 10 micron in front of it should extend its filtering life substantially
TNLoneWolf
17
Feb 21, 2008 06:22 AM
Tiara3100
Dec 21, 2007 01:42 PM
vwjunkie53
Nov 3, 2007 11:01 AM
Bham Ram
Mar 29, 2007 05:00 PM
HOHN
Dec 7, 2003 02:07 PM
