stock CHROME wheels
Old May 25, 2006 | 11:20 PM
PEAKSTRYDE's Avatar
stock CHROME wheels
Is it easy to remove the chrome from the wheel?
CAN IT BE DONE??????????????????????????????????????
I would like to see how a black wheel would look on my graphite truck!!!!!!!
Old May 25, 2006 | 11:45 PM
rockittboy's Avatar
uhhh....id say its easier and a better idea to go buy some black steel rims at the local tire shop, they are cheap and go that route
Old May 26, 2006 | 03:18 AM
TexasCTD's Avatar
My truck is not gray...it's black. But I had the OEM factory wheels sandblasted and powdercoated black. Maybe this may help you get an idea of what it would look like. Pics of the truck are in my gallery with and without the chrome center caps. Hope that helps.
Old May 26, 2006 | 03:22 AM
TexasCTD's Avatar
By the way.....These are on the Forged Aluminum wheels. I am not sure if the chrome wheels are different or not. If they are, I would suggest you get a set of take offs off of EBAY or something and have those sandblasted and powdercoated. Mine cost $80 to sandblast all 4, $100 total to powdercoat, and $48 to mount/balance etc.
Old May 26, 2006 | 11:08 AM
whiteDEESUL's Avatar
TexasCTD i cant read what size tire that is on the close up (bad eyes) i like your trucks stance ...leveling kit or stock? size tires?
thanks.
Old May 26, 2006 | 11:38 AM
derek840378's Avatar
you can get a 17x9 black steel wheel for somewhere in the neighborhood of $100
Old May 26, 2006 | 11:40 AM
thanks.
285/70/17. it looks to be stock height
Old May 26, 2006 | 12:38 PM
TexasCTD's Avatar
My tires are BFG AT KO 285/70/17s. I have a 2'' hell bent steel leveling kit on the front.
http://www.hellbentsteel.com/dodge/dodge-lift-kit.html
It did help lift the front nicely, but remember I have a 400lb Ranch Hand bumper and Milemarker 12,000 winch that is probably bringing it back down a little.
I looked at getting some aftermarket rims too, but the backspacing is not the same as the OEM wheels. I prefer the wheels to stay under the wheel well and not stick out beyond the fender unnecessarily. My suggestion if you wanted to go with aftermarket wheels, is to get a set of Hummer 2 wheel take offs and have those sandblasted and powdercoated. I just really like our OEM wheels.
Old May 26, 2006 | 01:19 PM
PEAKSTRYDE's Avatar
I looked at the H2 wheels, have seen them on our trucks, and can't decide if I REALLLLLLLLYYYYYY like them!!!!!!!!!!!!!!!!!!!!
I would like the wheels to have a little more offset than stock but I do not want them out tooo far either.
ANYONE HAVE A FRONT OR REAR VIEW OF A 2500 WITH H2 WHEELS??????
Old May 26, 2006 | 01:37 PM
i think the h2 wheels have a little bit more backspacing, because w/ 35's most ppl w/ stock wheels get rubbing on the link arms. i havent seen any rubbing w/ h2 wheels and 35's
Old May 26, 2006 | 02:37 PM
4x4not's Avatar
The chrome on the stock steelies is basically glued on. It can be removed, but it takes a lot of work. I had a set for awhile and the chrome had been cracking around the bead due to the 315s being too wide, but the glue was still TOUGH. I think you'd be happier with powder coated aluminums, either stock, H2, or aftermarket. I've always liked the look of the American Racing Teflon Mojave. they make them in the same size/backspacing as H2s I think.
Abbynormal
Jun 7, 2006 10:31 PM
Dr. Evil
21
Sep 27, 2005 02:50 PM
Tim9712v
Dec 9, 2004 04:44 AM
gaRam
Sep 23, 2004 10:05 PM
Dusty 96
Nov 28, 2002 09:01 AM
