Stock Boost & Spool
Old May 6, 2008 | 04:57 AM
RSOPNCO1's Avatar
Question Stock Boost & Spool
What is normal boost psi for a stock turbo? I will get about 3-4 cruising at certain speeds and about 17 or so when i accelerate. When should the boost start RPM wise? currently running the M3 tune on the X2. Wondering i if have low boost but no code. What would help me get a faster spool up?
Old May 6, 2008 | 09:26 AM
XLR8R's Avatar
Boost readings are low - are they from the Commander?
Verify with mechanical gauge.
Should max out ~ 32psi stock.
Old May 6, 2008 | 09:29 AM
stealman1's Avatar
I have only been able to hit 22 psi on my 03 so model. Reading is with a commander. Are the commanders known to be off?
Old May 6, 2008 | 09:35 AM
XLR8R's Avatar
Problems with electronic gauges are more likely than mechanical analog.
Your HE341 turbo won't boost as high.
Old May 6, 2008 | 11:01 AM
paroxysym's Avatar
no tune on mine with just an intake/exhaust im maxing/dumping boost at 28 psi. cruising at 60+ runs around 10 psi.
Old May 6, 2008 | 11:37 AM
blownsmoke's Avatar
Mine runs about 3-10 psi when cruising depending on terrain and right foot. I have seen 36 psi on the stock turbo with the edge in stock. which surprised the hell outta me..
Old May 6, 2008 | 09:42 PM
RSOPNCO1's Avatar
Using the commander to measure. Is the commander off reading too low? i think i hear the turbo start to spool b-4 i get a reading. How can i get a faster spool up?
Old May 6, 2008 | 09:52 PM
XLR8R's Avatar
Doesn't the Quad box boost-fool even when extra fueling is not engaged?
I know the Quad on our '05 does, as long as it's plugged in.
Stock fueling then produces 36-38psi boost worth of drive pressure on the HE351.
Old May 7, 2008 | 10:31 AM
paroxysym's Avatar
i know the quad xzt i ran on my 05 with stock lp, intake and exhaust would hit 42 psi max. surprised the heck out of me that it would hit that..
Old May 7, 2008 | 04:44 PM
Nate-03 D's Avatar
With a different boost elbow and a boost fooler I can get the turbo on my 03 SO to 33-35psi. I don't beleive they are that efficient when they are that high though.
Before I got my boost fooler if I touched 25psi it would pop a CEL for overboost. The truck sortive went into a "limp" mode until the code was cleared.
07BigHornRam
31
Mar 18, 2011 12:51 PM
camstruck
Jul 2, 2007 10:49 PM
D.Wiggs
Jan 4, 2007 04:24 PM
Tiger Rag
Dec 4, 2005 06:39 PM
