Stock Air Box Removal?
We are about to change the water pump on a 2004.5 , would like to remove the air box, see one nut holding it to the rad mount, however something still
holding is from underneath or to the rear side, is this box held in place with a few clips from underneath, don't want to break it trying to remove it..
Thanks
Thanks
From: Frozen Northern Minnesota, Darn Close To Where Perma-Frost Begins...
Should be just two push in pin/grommet. Remove the nut, top, etc. and just pull up on with a little wiggle like your pulling a tooth. Lube up the pins when you install makes assy easier.
jbham
14
Jan 26, 2009 09:20 PM
HeberRam
25
Apr 23, 2003 03:06 PM
