Steering feels like its stuck in 4x4
Old Apr 23, 2007 | 10:23 PM
cmiller's Avatar
Just this morning my steering feels like it is stuck in 4x4. When turning the steering wheel is pretty jerky, the slower the worse it is. I have the manual transfer case shifter and checked the linkage under the truck it moves at the transfer case. Could it be something else or did the linkage come undone in the case? Any other way to check this? thanks
Old Apr 23, 2007 | 10:39 PM
XLR8R's Avatar
Did you check your PS fluid level?
Old Apr 23, 2007 | 10:57 PM
cmiller's Avatar
I did but it was hot, the level on the dipstick looks like it should be checked when cold so I will check in the morning.
Old Apr 24, 2007 | 12:59 AM
XLR8R's Avatar
Turn the steering wheel to full lock and drive forward slowly - if you're in 4WD, you'll feel the truck lurch forward quite a bit through the front wheel universals.
Old Apr 24, 2007 | 02:03 AM
megafast's Avatar
If you do the above mentioned procedure in a gravel parking lot, you'll feel and hear the front tires scratching gravel.
Old Apr 24, 2007 | 05:59 AM
JohnnyH's Avatar
Probably axle U joints. I would check them first. When they bind up they can get real jerky.
Old Apr 24, 2007 | 12:01 PM
cmiller's Avatar
how do I check the u-joints? if they are hot after driving then they are bad? any other way to check? thanks guys
Old Apr 24, 2007 | 12:33 PM
vzdude's Avatar
DTR's 'Go to Guy'
With the wheels straight, try and wiggle the shafts coming from the diff. Also look for rust around the cap's seal - on the inside edge. 2 key places to look for wear.
Devinraptor
Sep 27, 2010 08:33 PM
Baja
Jan 29, 2008 08:17 PM
rockittboy
Feb 22, 2007 02:46 PM
Forrest
Mar 31, 2004 08:33 PM
