Help! - Feels like brakes are stuck on
Old Sep 25, 2010 | 04:59 PM
Devinraptor's Avatar
Hi Guys,
I have not been let down yet by this website, hopefully you can help out now. I have a 2006 ram it has been running fine, I drove it to work today and parked it, got in the truck to come home and it felt like I was driving with the parking brake on. I was almost pedal to the floor to get the truck moving form dead stop. Seem to go away as the truck got up to speed. It honestly felt like I was driving with the brakes on or pulling a REALLY HEAVY load. The brake fluid is a little lower than perfectly full but I don't think its any lower than it normally is, I really don't check it that often. It does it in reverse to. I pumped the brakes about 10-15 times really hard and now it seems to be okay but not sure for how long. Help! I appreciate it! I forgot I have 125,000 miles
Old Sep 26, 2010 | 07:10 AM
No one else experienced this?
Old Sep 26, 2010 | 11:30 AM
Ridiculies's Avatar
I've experienced the same thing. It turned out to be a sticky brake calliper, I replaced it and havent had any problems since.
Old Sep 26, 2010 | 12:31 PM
Hodge's Avatar
Yea, sounds like a sticking caliper. Does your truck have 4 wheel discs? You could jack it up and see which one is sticking. Even if it is driving better, you may be able to locate which one is sticking. And, if it were mine, I would replace both sides.
Old Sep 26, 2010 | 09:56 PM
Guardrail's Avatar
Sticky brake caliper vote here too. i had both my back ones go at different times. Drive it and check the wheels. The culprit will be much hotter than the others.
Old Sep 27, 2010 | 05:10 PM
Both the front calipers are sticking, and the brake lines on the front need to be replaced according to the shop. They also my pads were at 30% and I should replace my rotors now too. The grand total to Replace two calipers, front pads, front rotors, replace front lines and flush the system...................1000-1100.......My heart skipped a few beats when they gave me that number.
Old Sep 27, 2010 | 05:30 PM
15 Digger's Avatar
I'm selling my truck and buying a smart car.
Old Sep 27, 2010 | 05:42 PM
after that quote i might have to agree ha ha
Old Sep 27, 2010 | 08:02 PM
sticky's Avatar
Check to see if the caliper is getting hot after driving a short distance.
Sticky
Old Sep 27, 2010 | 08:33 PM
05CTDN8's Avatar
Pads for the front - 65.00 / both
Rotors -210.00 / both
fluids - 20.00
Calipers - 155.00 / both
Uh....where is the rest going? Do it yourself!
Baja
Jan 29, 2008 08:17 PM
cmiller
Apr 24, 2007 12:33 PM
Forrest
Mar 31, 2004 08:33 PM
70DUSTER
May 15, 2003 02:53 PM
gunracer1
May 8, 2003 05:59 AM
