Steady bearing?
Old Oct 7, 2009 | 07:59 PM
69nova's Avatar
Steady bearing?
My truck makes a knocking sound and vibrates like hell. No its not the u-joints. Its really bad at about 40kph, but is felt and heard all the way from start to 150kph. I can push on the driveshaft by the steady bearing and it moves quite abit (the rubber part), like 3/4 of an inch. Is this normal play for the steady bearing? Any other thoughts on what the knocking could be?
Old Oct 7, 2009 | 08:36 PM
trik396's Avatar
Ok... I gotta ask... what's a steady bearing??? I've been thru my truck front to back and never heard of it.
Old Oct 7, 2009 | 09:10 PM
69nova's Avatar
On crew cab long box trucks, the drive shaft is two pieces. Its a part thats in the middle of the two shafts, that supports it to the truck.
Old Oct 8, 2009 | 07:26 AM
patdaly's Avatar
Carrier bearing........... And it would be my first thought.
Old Oct 8, 2009 | 07:30 AM
trik396's Avatar
Carrier bearing.... that's the name I knew it by...
Old Oct 8, 2009 | 10:58 AM
Turbo04's Avatar
Sounds like a carrier bearing problem to me as well. If you want to duplicate this problem on a smaller scale, take an air wrench, 2 extensions and 3 u-joints (one on the driver then an extension, then a u-joint then the other extension and then another u-joint) stick a socket on the end and try to remove or tighten a bolt and watch the center u-joint, if it is not securely fastened in place to something (like how a carrier bearing is supposed to be) then it is going to go crazy jumping around.
This will duplicate the setup of you drivetrain from output of the trans to the rear end.
Don T
Aug 12, 2013 10:58 PM
DC199512V87
Mar 4, 2012 11:40 AM
bensdad_canada
Aug 1, 2005 09:12 AM
roadrattler
Nov 18, 2004 10:12 AM
ppsi
Feb 10, 2004 05:52 PM
