Spare Trans cooler install
Old May 28, 2012 | 07:12 PM
Big Show's Avatar
I'm installing a spare trans cooler. And was wondering what line to tap into out of the trans top or bottom line??
Old May 29, 2012 | 09:51 AM
.boB's Avatar
Depends on what kind of driving you do most often. If the trans fluid does not get up to a certain temp, the trans will not up shift into OD.
Since you live in IL, you would want the fluid to flow through the auxillary cooler first, then to the heat exchanger in the radiator to warm itup a little if it needs it.
If you lived in a desert climate, you would want to plumb it into the return line, after the exchanger. Then you get some additional cooling just before it goes back into the trans.
Old May 29, 2012 | 11:05 AM
Big Show's Avatar
Thanks the feed line is the one I have leaking so that will save some cash. Just getting it ready to head to Colorado in 2 weeks
92smokin blacky
Oct 30, 2012 06:30 AM
DNRCustoms
Nov 19, 2008 09:09 PM
DodgeDiesel61
Sep 18, 2008 10:55 AM
Boatnik
Nov 6, 2007 07:52 PM
live wire
Jul 21, 2003 07:26 AM
