Sounds like a spitting air leak in my 5.9 '06
Old Mar 18, 2011 | 05:23 PM
shima's Avatar
As stated in the title, it sounds like I have a pressure air or vaccum leak on my '06 5.9 CTD. The sound appears to come from the driver's side. Is there a valve, hose, or filter that may be dry rotted causing a leak like that or something? I haven't noticed a lack of power, but the sound worries me. Any ideas? Thanks, Shima
Old Mar 18, 2011 | 05:49 PM
Hvytrkmech's Avatar
Check the clamps on the air to air tubing boots and make sure they are tight. Also look for tears in them. I am betting a loose clamp.
Old Mar 18, 2011 | 09:08 PM
TedT's Avatar
I bet the noise is coming from the power steering / power brake fluid lines.
Old Mar 20, 2011 | 10:57 AM
no_6_oh_no's Avatar
Does it change when you step on the brakes?
If it does, its a bad hose on the hydro boost pump. replace them to cure the issue.
Old Mar 22, 2011 | 11:06 AM
MTC's Avatar
MTC
^^^what he said...I had a hissing noise from the area you re talking about...it was one of the hoses from the hydro boost.
Old Mar 23, 2011 | 07:47 AM
shima's Avatar
No change when I put the brakes on. It seems to only be when I have my foot on the accelerator pedal. I hear it most at around 1500 RPMs when the engine isnt running as loud. And as I said, when I take my foot off the pedal, the noise goes away. Thanks for the inputs.
Old Apr 3, 2011 | 04:33 PM
shima's Avatar
An update on my noise. It sounded like a ticking as a leak would sound and I found it was a loose clamp on the #4 fuel injector line. It was vibrating in the loose clamp. Once I tightened the clamp, the ticking sound went away. who would've thunk it?
Old Apr 3, 2011 | 11:51 PM
OOPS's Avatar
Common problem.
Old Apr 4, 2011 | 06:42 AM
AH64ID's Avatar
Good catch, it is a common problem and normally isn't noticed until the line ruptures.
Old Apr 4, 2011 | 12:23 PM
ssandlin's Avatar
Glad you found it before it ruptured and left you stranded somewhere! I check all those clamps every oil change.
lspindl3
Jul 9, 2013 10:44 PM
krusty 2
Oct 6, 2011 05:14 PM
superdiesel9
Oct 25, 2009 07:56 PM
RNX CTD
Oct 18, 2007 09:43 PM
MR. GADGET
Aug 2, 2007 12:30 PM
