Shifting without the clutch
Old May 10, 2007 | 07:45 PM
Topper's Avatar
Hey Guys,
I had my dad with me the other day when he realized I wasn't using the clutch when I shifted. Well when I was taught how to drive years ago in that old Diamond Rio I was taught not to use the clutch. The only time we used it was for stopping or starting. Now my dad was saying that our trucks aren't designed to be shifted with out the clutch but I of course I told him that he was crazy and not to worry about it. Well I was wondering, anyone else shift without the clutch? I haven't used a clutch to shift in over 20+ yrs and never had any tranie troubles. (Due to shifting that is)
So how many of you guys shift with out the clutch? If you haven't given it a try -TRY IT YOU WILL LIKE IT!!!
See ya,
Topper
Old May 10, 2007 | 08:02 PM
madhat's Avatar
Administrator/Jarhead
I did in our old 92 dodge... when it would let me. And in my dad's rig, a corn grinder. Not lately, tho. Tried to do it in an 06 handshaker I test drove the other month, I guess that the syncros were not broke in yet...
Old May 10, 2007 | 08:26 PM
03 ant a hemi's Avatar
If you can shift with out grinding then it is fine.
Old May 10, 2007 | 08:28 PM
madhat's Avatar
Or... if you can't find 'em, grind 'em!
Old May 10, 2007 | 08:40 PM
Totallyrad's Avatar
It's really not a good idea. On these transmissions you'll wear out parts fairly fast. They'll pop out of gear.
Old May 10, 2007 | 08:45 PM
SolarYellow05's Avatar
Shifting without a clutch with a road tractor transmission is different because you have no synchronizers or partial synchros. That is why there is no difference with the clutch in or out. It is harder on the synchros in smaller trucks like ours and also harder to shift without the clutch. It will wear out the synchros faster.
Old May 10, 2007 | 09:01 PM
annabelle's Avatar
Did it in my 70 GMC with a M456.....no issues, just time the RPM's
Old May 10, 2007 | 10:04 PM
tbarbee1's Avatar
I never used the clutch on my 97 237,000 miles but my 07 with 14,000miles isnt as shifter friendly I tried it a couple of times it may get better as it breaks in
Old May 11, 2007 | 02:55 PM
DiEseLjunKy's Avatar
You're asking for trouble shifting a fully synchronized transmission without the clutch. It's there for a reason. Use it. Even on the big trucks without synchros it's not good for them.
Old May 11, 2007 | 07:15 PM
Raspy's Avatar
The only time you might hurt the synchros if if you are pulling hard on the shifter with mis-matched engine RPM, and you do it over and over. And then it won't go in anyway. Just match the speeds and it won't hurt a thing. Kind of fun too. You might even save a little ware on the throwout bearing and clutch.
Wetspirit
Old May 11, 2007 | 09:30 PM
Originally Posted by Wetspirit
The only time you might hurt the synchros if if you are pulling hard on the shifter with mis-matched engine RPM, and you do it over and over. You might even save a little ware on the throwout bearing and clutch.
Wetspirit
Thing is nobody's perfect and guaranteed every one of you shifting without a clutch have mismatched a few times a day. Like most truckers too lazy to mash the clutch pedal I float shift my big truck a hundred times in a day and I mismatch it every now and then. If I was double clutching it, as one should, mismatches would never happen. So if you want to be cool floating them in a $40K pickup truck go right ahead. I'm just not chancing it in my Ram.
Old May 11, 2007 | 09:35 PM
goodeyesniper75's Avatar
i shift without the clutch most of the time, unless im towing...
Number4b
Jul 27, 2014 11:54 AM
illEatUrDuramax
31
Mar 24, 2010 01:03 PM
FLgrinder
13
Dec 10, 2007 04:00 PM
Farming600
May 25, 2004 05:45 PM
rich
Dec 15, 2002 07:38 PM
