shifting problem
Old Jun 3, 2013 | 08:26 PM
sotex's Avatar
shifting problem
It's been a while since I posted and I posted this to another thread- sorry 'bout that! At any rate...
I have a 2004.5 Dodge 4x4 auto with about 165,000 miles on it.
I replaced the 1 to 2nd gear solenoid with a GM solenoid about 60-70,000 miles ago.
Now, it hangs in 1st gear until about 2000 to 2500 RPM before it shifts into second. Under light throttle, pulling a light load, going up hill, it feels like it slips out of second into neutral. When I back off the throttle it goes into second. With light throttle pressure again, in about 10 seconds it happens again.
The problem only seems to exist under light throttle, with a light load, going up hill. More or heavier throttle in second seems to keep it from happening.
All else seems to be the same. Also I have about 10-15,000 miles on this trans fluid and filter change.
Any ideas?!?
__________________
Old Jun 5, 2013 | 10:43 AM
Skipit50's Avatar
sotex,
My truck did the exact same thing. Eventually 2nd gear went out completly. It continued to hang in 1st gear like yours does then it would shift from 1st to 3rd. Skipping 2nd altogether. I adjusted the fwd band but it didnt help. I ended up pulling the transmission and found the fwd band completly worn out to the point where it scratched up the drum.
Old Jun 5, 2013 | 09:37 PM
sotex's Avatar
I ran a diagnostic on it today and it indicated that the transducer (it regulates pressure) is faulty. I'm going to replace it to see if that fixes the issue. THANKS for responding - I'll let you know!
Old Jun 10, 2013 | 08:41 AM
sotex's Avatar
replaced transducer. @ filter +traney fluid shifting problem gone. working great
Old Jul 31, 2013 | 08:39 PM
Z-MAN's Avatar
I have the same problem but I didn't know about transducer. Where is it located and how did you change it, is it hard? Thanks.
Old Aug 9, 2013 | 09:27 AM
sotex's Avatar
trans ducer
it is next to govenerpresure solonid easy fix sory about late response.
Brendan
Oct 17, 2007 11:12 AM
98 Ram 24V
Dec 24, 2005 10:19 AM
fourwhls00
Aug 4, 2004 10:04 PM
Cumminsdude
Aug 13, 2003 12:50 PM
warden
Feb 23, 2003 10:20 AM
