Shift points during fast acceleration...
Old Sep 16, 2005 | 03:53 PM
dieselnewbie's Avatar
Question Shift points during fast acceleration...
Whenever I get on the go-pedal pretty aggresively, from idle speed, say from 0 MPH to 60 MPH, shifting is pretty smooth up until the last gear, then it seems to shift almost twice inside of 5 MPH (happens when I hit ~50 MPH), or maybe it's slipping(???) but I doubt that.
Maybe it's a passing gear that only kicks in at elevated RPM's at that speed?
Anyone ever notice this? After I get past that funny last shift it smooths out. It doesn't grind at all but when that happens the tach spikes up a bit and winds for a second and then settles, that's why it seems almost seems like a slip.
If I accelerate with normal speed (not as fast) from 0-60 I never notice it. It shifts up through the gears with no double-shift.
Anyone ever experience this?
Thanks alot,
DT.
Old Sep 16, 2005 | 04:17 PM
Strick's Avatar
When accelerating hard it shifts into 3rd, then you get converter lockup, immediately followed by a shift to fourth. The lock up and shift to fourth is what you are feeling close together.
Old Sep 16, 2005 | 09:19 PM
Thanks Strick.
Just wanted to make sure nothing was busted.
That sounds exactly right.
DT.
Old Sep 17, 2005 | 07:49 AM
Blue600's Avatar
Mine does the samething.
Old Sep 17, 2005 | 04:56 PM
TexasCTD's Avatar
so does mine
Old Sep 17, 2005 | 05:00 PM
cantfindaname's Avatar
Mine does too. I always thought it was the converter slipping.
Old Sep 17, 2005 | 05:03 PM
Is there anyway to smooth out that lockup and shift into 4th?
Old Sep 17, 2005 | 08:11 PM
drew03's Avatar
should have got a 6 speed, then you will know why it is shifting.
csramsey640
May 18, 2020 12:34 AM
can17
Jan 18, 2008 09:48 PM
Monty
0
Feb 14, 2003 07:14 PM
RJMontana
Feb 14, 2003 06:44 PM
