Seized FCA Screws
Seized FCA Screws
Well, I'm another one that got bit in the ****. 2 of em need an easy out, but I want to get them un-stuck so I don't snap an easy out, or twist a screw off in the CP3. What methods have you guys/gals used? I was thinking a punch and hammer.
if vice grips fail:
i work on heavy equipment along with other things, i have problems with the 4 allen bolts that hold on hose flanges, once in a while the allen hole is rusted out. i try to tap in something bigger, if all else fails i cut the head off carefully with a cut off wheel, pull the part off, the screw/bolt screws out with pliers 99% of the time.
I was getting really bad injector rattle. Sometimes it was at idle, sometimes when I got the rpm up to 2200, and once in a while it did it no matter where the rpm was. Since I changed it, rattle went away, throttle response got better as did power output. BTW, I'm talking about the FCA, not the screw.
when i bought mine 3 months ago it sounded weird at idle when cold.
sence then i had a no start issue and the FCA code. changing the FCA made it run sweet but 2 days later it would not start again.
injectors fixed that, had 1 bad one.
i added a rail pressure gauge so if it returns i will have a cool tool to help isolate the problem. i think the rail pressure was going up and down causing a loud then quite idle.
