rubicon transfercase
Old Jan 2, 2008 | 09:31 PM
stumpjumper's Avatar
has anyone heard or installed the rubicon t-case behind a 48re? i read a recent article of a jeep that had a srt-10 engine and trans in it. just curious about getting the 4to1 ratio for crawling.........
Old Jan 2, 2008 | 09:42 PM
j's Avatar
j
i dont think it would hold up very long behind a diesel. if you're even thinking about swapping t-case's for a lower gear ratio, i would suggest an atlas or stak box. owned an atlas, and only seen a stak4x4 box, both are more than adequate for the job and have plenty of ratio's to chose from.
Old Jan 2, 2008 | 10:27 PM
GOTMEAT's Avatar
I own a Rubicon. That NV241 is a great case for a lightweight low-powered Jeep.
You will need a case designed for a 1-ton to not break it. 4:1 kits are available for most cases and come at a lot less cost than a new case.
Why do you need 4:1? It is really too slow for anything besides rock crawling.
Old Jan 2, 2008 | 11:09 PM
gmctd's Avatar
The NV241 in the Jeep is identical to the NV241 in the Dodge trucks, except for one small thing(s) - the shafts look like they may have been designed for a lawn tractor - so, even tho it's physically the same size, crawl one small rock and it'd be stoned...............
Old Jan 3, 2008 | 06:50 PM
thanks for the replys. the only time i use low range is crawling. do you know of any specific company that makes a 4:1 for our t-case?
Big Dblue
Nov 2, 2009 08:11 AM
Big Dblue
Sep 27, 2008 11:52 AM
RyeThomas
Mar 17, 2008 06:54 AM
Dogin
22
Mar 10, 2008 02:01 PM
Syndicate
Jul 19, 2007 04:19 PM
