Rough start up & blue smoke
Old Aug 26, 2008 | 05:10 PM
92'1stGen's Avatar
(Now in the right section)
Well I went out and started my truck (06') yesterday morning, about 11 am, it was around 80 degrees out. Cranked it and it start real rough and blew a small puff of blue smoke out the pipe about the size of a plastic grocery bag filled with air. It smooth out after a few seconds. I didn't drive it at this instance, I was only moving it to adjust the tire pressure. I got back in it about 3 hours later to drive into town and it starts up fine like it usually does. It seemed to have all it's power and was fine.
Got in the truck this afternoon, about 12:30, it was around 70 degrees out. Cranked it and it did it again but it took slightly longer to start and seem rougher, and also another small grocery bag sized blue puff of smoke out the pipe. Again it seemed to have all its power and acted as if nothing was wrong.
I just had my oil changed on Saturday morning at the dealership, as I have a few free oil changes, but I never had a problem with it until yesterday. It was driven multiple times on Sat and Sun and it was fine. I haven't gotten around to checking the oil level but, whenever I start it later during the day, after the 1st initial start, it doesn't give me a problem.
What do you all think? leaking injector?
Old Aug 26, 2008 | 05:20 PM
louddodge's Avatar
does it fire up like normal or take a little longer than normal? It sounds like one maybe leaking down.
Old Aug 26, 2008 | 05:28 PM
92'1stGen's Avatar
maybe like a second or 2 longer.
Old Aug 27, 2008 | 06:29 AM
92'1stGen's Avatar
bump to the top
Old Aug 27, 2008 | 05:27 PM
TXCTD01's Avatar
I took mine in on Thursday of last week because it was idling rough to me and it turned out to be a bad injector. Luckily for me it was still under warranty. I did not however look to see if it was blowing any kind of smoke at start up. Hope this helps.
Old Aug 27, 2008 | 07:36 PM
92'1stGen's Avatar
Yep that sounds about exactly the same as mine. I'm going to take it in next week and have them look at it, no sence in doing it tomorrow though as it probably won't get looked at before the weekend and it would just sit. Thanks
Txbigfoot
Feb 26, 2013 03:24 PM
92'1stGen
Aug 26, 2008 02:45 PM
BLUEBURNER
Oct 19, 2007 09:29 AM
$oC@l CTD
40
May 5, 2007 08:18 PM
big red psd cc
14
Sep 1, 2004 01:39 PM
