rough shut down
Old Feb 21, 2007 | 07:26 PM
matt ellerbee's Avatar
rough shut down
everytime i turn the truck off it will continue running for a second then shake the whole truck alot, my powerstroke never did this or it wasnt as noticable.
could there be anything wrong with it as its brand new?
2006 2500 4x4 6speed all stock...1500 miles.
Old Feb 21, 2007 | 07:31 PM
magram's Avatar
Shaking the truck at shut down is common in a dodge cummins, but I never heard of running for a second after shut down.
Take it to the dealer for warranty!!
Old Feb 21, 2007 | 07:40 PM
well its not really still running i dont guess. more of a everythings kinda slowing down feeling.
Old Feb 21, 2007 | 08:12 PM
kelley15's Avatar
There is alot of compression that stops immediately. The pulleys try to keep spinning. It is pretty normal on a Cummins. Press in on the clutch when you kill it. That will be more smoother even if it is in neutral. TRY IT.
Old Feb 21, 2007 | 08:13 PM
ClackClack's Avatar
Mine goes 'Futh-a-thump-chirp!' Say it out loud... it's like that!
Old Feb 21, 2007 | 08:19 PM
haha ok thanks guys, ill try the clutch in next time i shut down.
'Futh-a-thump-chirp!'.....thats about right to!!
Old Feb 21, 2007 | 08:20 PM
NoChrome's Avatar
I got a 6spd too and it has always done it, its called the cummins shudder.
Old Feb 21, 2007 | 08:38 PM
auSS/Tin's Avatar
That is how you know you got a serious engine in there. I have seen plenty of big rigs shudder when they shut down.
Bill
Old Feb 22, 2007 | 04:32 AM
Dodgezilla's Avatar
It seems to be worse with these Dual Mass Flywheels guys. I always depress the clutch when I shut down and it's much less violent. There's a guy on another board that works for the company that makes the DMF and he says that it is the culprit....
Old Feb 22, 2007 | 05:30 AM
4x4not's Avatar
I dunno DZ.... my single disc truck shakes a lot on shutdown too
Old Feb 22, 2007 | 06:07 AM
Riddler69's Avatar
Auto
I have auto tranny and my shudders quite a bit at shutdown. I was wondering myself if something was wrong, but it has done it from day 1.
Old Feb 22, 2007 | 06:27 AM
The Boss Hog's Avatar
Its normal, but be sure and keep your doors shut until after it stops. Otherwise, you end up with doors that raddle.
The Boss Hog
Old Feb 22, 2007 | 07:00 AM
Dodgezilla's Avatar
4x4Not, The dual mass flywheel is not the same as a dual disc clutch.
All these trucks shutter some when you shut them down. You are stopping a lot of torque. As I said, I always depress the clutch and it's less violent. Maybe you auto guys could try shutting down while in gear and see if that helps. Just don't forget to put it back in park....
Old Feb 22, 2007 | 07:50 AM
ClackClack's Avatar
But I like the shudder! It scares the yuppies in the mall parking lots!
Old Feb 22, 2007 | 02:01 PM
ok, the clutch in trick helps some but it still feels like its falling apart, but it is growing on me
dkimmel
Jan 3, 2011 10:54 PM
randyswelding
Feb 9, 2009 10:40 PM
Mexstan
Mar 31, 2003 02:37 PM
dsl-man
Mar 20, 2003 02:57 AM
rattle_rattle
Nov 11, 2002 02:40 PM
