removing and cleaning injectors
Like Mike B said pour a 32 oz of Power Service along with 10-12 oz of MMO or 20 oz of Lucas in your tank and take it on a long hard work out to get the engine hot. This will help to clean the carbon off the injectors. Heck even Cummins has been known to give the same advice for this problem. If you try this first and it does not work then pull the injector but not before you try the PS or Lucas as it could save you some $$.
Good Luck.
Good Luck.
Great info! Thanks so much for taking the time to reply. So do the nozzles just screw out of the injector body? Does anything come free when you remove the nozzle?
I'm leaning toward just replacing the nozzles but I just want to know what I'm getting into with taking the injectors apart before I decide.
Thanks again for the helpful post. Cheers!
madhat
Nov 21, 2014 06:22 AM
smokinram99
Jul 20, 2008 06:07 PM
