Removing Cleaning the Valve Body 47RE
Old Jul 16, 2008 | 04:17 PM
smokinram99's Avatar
I have some trouble with my tranny after a fluid and filter change...wont upshift when cold from 2nd to 3rd... RPMs goes up and it's like it slip!
I have already replaced the Governor Pressure Sensor and the Tranny output speed sensor BUT nothing change..
Can I try cleaning the valve body? how to take out of trans? what can I clean..the valves? I need to disconnect the linkage or other parts before?
any help will be much apprecciate!
rob
Old Jul 16, 2008 | 07:51 PM
Shovelhead's Avatar
Administrator / Scooter Bum
My Auto tranny dipstick was reading too low.
I added another 1/2 to 3/4 quart of ATF after getting some slipping and poor shifts following my last tranny fluid change and it made all the difference in the world.
Old Jul 16, 2008 | 09:27 PM
dozer12216's Avatar
Ditto on running just a pint over full in neutral.
Your description sounds more like Governor pressure soleniod instead of sensor.
Has KD band been adjusted proper? Or plum out of adjustment on locking nut.
Old Jul 20, 2008 | 06:07 PM
I ordered the governor solenoid and also TCC & OD solenoid...I'll try w these parts and also a band adj..
it wont upshift only when cold...If I drive it a bit, highway and city, about 5 or 10 miles it then shift properly....!!
kevellis32
27
Jun 23, 2022 01:42 PM
downlow
Feb 13, 2007 07:45 AM
xtremexj
Aug 14, 2006 09:42 AM
storx
28
Jan 28, 2006 08:12 PM
badmrb
Nov 28, 2005 11:02 AM
